Yellowhand
- Mar 15, 2025
- 11
Is this cam on a small (1.050") base circle for rod clearance .COMP Cams Xtreme Energy Retrofit Camshafts 12-443-8.
Where to buy .950 BCI would say yes.
I have run as low as .950 and had no issues.
My cams are often custom grinds to my specs. The one in question was a Comp Cams.Where to buy .950 BC
I have Eagle 5140 steel "SIR" I- beam connecting rods with Wiseco flat top w/ 2 valves reliefsIf given the choice, or the OP has the option, just get a con-rod with profiled shoulders and avoid the weaker small base circle stuff.
Good rod choices out there.
I'd rather get the required clearance by way of the proper rod and lift by way of rocker ratio.
Those small base circles cams break just at the wrong time LOL !!!
NB: That CC 12-443-8 requires only 9.5cr and has a base of 2,800 to 6,100 rpm. Kind of mild for 242 @ .050.
I have profiled the rods with a belt sander prior to balancing.I have Eagle 5140 steel "SIR" I- beam connecting rods with Wiseco flat top w/ 2 valves reliefs
What CID engine are you building?Is this cam on a small (1.050") base circle for rod clearance .COMP Cams Xtreme Energy Retrofit Camshafts 12-443-8.
