ZZ502 fits under stock 1980Z hood, pics
Discussion in 'Project Progress' started by Chipman, Aug 11, 2008.
  1. Chipman
    Chipman Veteran Member
    110
    Jan 24, 2008
    North Louisiana
    Finally got a chance to reinstall the hood today. It fits, but its tight.
    View from drivers seat.
    Hole cut in the hood[​IMG]
    Front view
    Closed hood
  2. iregret
    iregret Veteran Member Lifetime Gold Member
    1,094
    Apr 21, 2003
    Land of enlightenment.
    Right on man! Good job! I can't wait until I get to the motor install on Cindy.
  3. woody80z28
    5,495
    26
    Sep 8, 2004
    walton, ny usa
    How the........
    I have that same drop base air cleaner on my 355 and it wont poke through the hood, it's off too far to the pass side. Yours looks like it pokes all the way through. Is that a 15" hole in the hood? You can't get much bigger and have the scoop still cover it.
  4. Chipman
    110
    Jan 24, 2008
    North Louisiana
    Hole size
    I don't know the size of the hole. I started at each edge of the cowl and oblonged the hole to the front and the rear. Only got 1/2 inch or so on passenger's and driver's sides. The entire top of the cleaner is in the hole. Nut is also very close to the cowl but I can move the hinges up a little. The hood lines are bad anyway.
  5. woody80z28
    5,495
    26
    Sep 8, 2004
    walton, ny usa
    I'm wondering if your BBC is centered in the engine bay differently than my SBC. Maybe I can try oblonging my hole also to the pass side. I dont think I have much room at all though until the scoop would no longer cover the hole in the hood.
  6. Chipman
    110
    Jan 24, 2008
    North Louisiana
    I cut mine right up to the cowl and cut the support ridges out of the cowl. It tooke every bit of space I could get.
  7. Chipman
    110
    Jan 24, 2008
    North Louisiana
  8. EricsZ28
    EricsZ28 Veteran Member Lifetime Gold Member
    3,486
    Feb 28, 2006
    Here and there...
    Nice job. There is more room under those scoops than people think.
    Out of curiousity, did you gut the scoop completely? I didn't see the door on the back & I noticed the solenoid mounts & those intermediate mounting stud bases were cut down flush. Is it just open in the back?
  9. Chipman
    110
    Jan 24, 2008
    North Louisiana
    Yes it is open in the back. Had to remove everything and cut of the mounting posts to get enough room.
  10. woody80z28
    5,495
    26
    Sep 8, 2004
    walton, ny usa
    Maybe that's my issue. I'll take the scoop off and see if things will fit. I think my biggest problem is the wedged body bushings.
