ZZ4 Vibration
Discussion in 'Troubleshooting & Diagnosis' started by Jeff76LTZZ4, Nov 4, 2004.
  1. Jeff76LTZZ4
    Jeff76LTZZ4 Veteran Member
    101
    Apr 15, 2001
    Montgomery, Texas
    Hey guys I have question some of you might have a suggestion on.I installed a ZZ4 Crate Engine in my 76 Camaro and it
    has had a vibration at 1000-2000 rpm from day one. It smooths out at lower
    or higher rpms. I was wondering if it might be the coil, cap or maybe plug
    wires. What do you think?
    Thanks
    Jeff [​IMG]
  2. ZZ430
    ZZ430 Veteran Member
    619
    Jul 9, 2004
    Crockett, Texas
    Did it come with the correct external balance flexplate?
    My Camaros
  3. Jeff76LTZZ4
    101
    Apr 15, 2001
    Montgomery, Texas
    Yes I belive so.
    I should have listed more details. I also installed a rebuilt Th350 with new torque converter.
    Thanks
    Jeff
  4. Jeff76LTZZ4
    101
    Apr 15, 2001
    Montgomery, Texas
    It is not a bad vibration. It almost feels like I have solid motor mounts. I installed new gm mounts when I did the intall. Just seems like it should be smoother. I was also thinking it might be the torque converter. That is sort of what it feels like, if you have ever experienced it.
    Thanks
    Jeff
  5. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,204
    9
    Jun 10, 2001
    Selah, WA
    I would check the motor mounts, and harmonic balancer and make sure the tranny is bolted up tight. If the vibration was comming from the rear id say look at your driveline.
  6. ZZ430
    619
    Jul 9, 2004
    Crockett, Texas
    Try turning the torque converter to one of the other 2 positions on the flexplate and see if it helps.
    My Camaros
  7. Jeff76LTZZ4
    101
    Apr 15, 2001
    Montgomery, Texas
    I will check on those things again. It has the vibration in neutral as well. I was mistaken earlier in the Rpm, vibration starts a 1000 and the smooths out
    Jeff
