zs8 engine code p0410
Discussion in 'Camaro Questions' started by djsz28, Jul 5, 2006.
  1. djsz28
    djsz28 New Member
    Jul 5, 2006
    lexington ky
    I have a chance to buy a 96 z28, the seller says it has a engine code of
    p04109 ( secondary air injection malfunction ) he says it has not caused him any preformance problems and he has not had a chance to get it repaired.
    The problem is the car is in Florida and I will have to drive it to Kentucky
    does anyone think it will give me a problem to drive it that far?
  2. 79silverz28
    79silverz28 Veteran Member
    726
    Jan 6, 2006
    Texas
    No, not a real problem....however...
    ...You could have him clear the code to make sure there's nothing else. Probably an air pump died or the EGR is stuck.
    If he doesn't have a reset tool, just unplug the ECM fuse for a few minutes, and see if the error comes back. You can remove and program out that code so it doesn't come back with LT-1 Edit [and then just remove all that equipment]. If you think you might be doing any mods to the car in the future, you will want this package anyway.
  3. djsz28
    djsz28 New Member
    Jul 5, 2006
    lexington ky
    thanks great info
