Z28 wheels
Discussion in 'Camaro Questions' started by nogoty, Nov 19, 2006.
  1. nogoty
    nogoty Veteran Member
    147
    May 10, 2006
    if I use an early 70's standard five spoke Z wheel on my 80 Z with the three originals, will it look exactly the same or are there some differances? Pease dont say there diff. cause I already bought one from E-Bay and its on the way!!
  2. Gary S
    21,083
    309
    It will look slightly different. The hole in the 5 spoke part of the rim where the valve stem comes through will be a different shape. Also, you will notice that on the early rims, the trim ring fits flush with the wheel so only the side facing out from the car is visible. On the later rims, you also see about 1/4" of the side of the trim ring when it is installed.
    The details are here:
    http://www.nastyz28.com/2gcog/stegmiller/z28_wheels.htm
    There were 4 different versions of this wheel. Once you have your wheel and see exactly which version it is, you can probably trade that one for one like the ones on your car. I think you will find quite a few people on this board that have some, and if anyone is living in your area, you could probably work a trade without having to pay for expensive shipping.
  3. nogoty
    147
    May 10, 2006
    Is it going to stick out like a sore thumb to someone who doesnt know alot about camaros? I dont mind if it looks alittle different
  4. MadMike
    MadMike Administrator Staff Member
    13,566
    34
    Feb 11, 1999
    Dawsonville Georgia
    The only people who'll notice any difference (and it would be nit-picking) is folks like chuck, me, gary... those who know what the differences are (as evidenced from above). But we keep our mouths shut.
    For all practical purposes, the wheel will match whatever is on the car now. Nobody will notice.
  5. nogoty
    147
    May 10, 2006
    Thanx madmike! Thats what I wanted to hear:D Ill get the right one someday at a swapmeet but I jumped the gun on ebay and didnt research first Oh Well. Are you the guy that started this site? If so thanx It helps alot!
  6. COPO
    16,340
    264
    The flush mounted trim ring looks better than the later rims, so if you can get more it will make the rims look better.
  7. camaro73lt
    camaro73lt Veteran Member
    903
    Feb 6, 2003
    Hanover, PA
    Trade Z28 wheel?
    NOGOTY - I may have a deal for you... I need an early 70's Z28 wheel that's correct for my 73 to complete my set. I believe I have two of the later 80's style Z28 wheels described here and would be glad to swap a wheel with you. Wheel is perfect and painted. You will probably need to paint for your needs. Has the OEM finish on it. Not sure what paint was used. I think it was the MX101 or MX102 "grey". I can get you a pic and the date codes if you want. I need to unbox them to get an accurate inventory. Anyway, if you're interested, let me know. I got stuck with a mis-matched set also before I learned the hard way to do my research first.
    MadMike / Gary / CamarosRUS - thanks for this awesome info regarding these wheels! You guys are the gurus!
  8. nogoty
    147
    May 10, 2006
    OK camaro73lt mine is an AU code I still havent actually gotten it yet should have been here by this Fri. but the holiday stuff will screw that up. But it is supposed to have the correct beauty rings and center cap and it has been painted black so Ill let you know when I get it!
  9. Budz
    2,925
    36
    Mar 17, 2002
    Ashburn, Va USA
