Z28 Rims
Discussion in '1970 - 1973 Specific' started by rsbad454, Jun 2, 2016.
  1. rsbad454
    rsbad454 Veteran Member
    101
    Sep 23, 2015
    NorCal
    Are there differences in the Z28 rims for the second gen Camaros? I have one rim where the beauty ring appeared to show more if it's inside lip in comparison to the inside portion of the rim. The other three rims inside portion appears to hang over entire inside lip of beauty ring where it makes its bend toward outside lip of rim. You can clearly see the rim is either narrower or inside portion sticks out more in the second pick.
  2. 81BirdMan
    81BirdMan Veteran Member
    785
    Jan 31, 2004
    http://www.nastyz28.com/faq/wheel/z28wheel.html
    You will be able to tell the rough year usage from the valve stem hole and the fit of the trim ring. Early wheels have oval valve stem holes. The early 1970 wheels measure 1" x 5/8", midway through the year the valve stem hole was enlarged to 1" x 13/16". On these wheels the inner portion of the wheel protrudes approximately 1/8" beyond the outside lip of the wheel so when the trim ring is mounted only the flat portion facing the outside of the wheel is visible.
    By contrast, the later wheels have round valve stem holes. The 1977 - 1978 valve stem holes are 7/8", while 1979 - 1981 are 1". On these, the inner portion of the wheel is set approximately 1/4" lower than the outer wheel lip so that when the trim ring is in place about 3/8" of the horizontal part of the trim ring is visible.
  3. rsbad454
    101
    Sep 23, 2015
    NorCal
    Looks like I have one early and 3 later rims.....thanks for the info.
  4. FlaJunkie
    6,088
    117
    Mar 24, 2001
    Rockledge, Florida
    Read the number on the different one around the valve stem hole...inside rim. Let us know what it is and we can tell you what year it is.
  5. rsbad454
    101
    Sep 23, 2015
    NorCal
    I'll do that, thanks for the info.
  6. Budz
    2,976
    45
    Mar 17, 2002
    Ashburn, Va USA
  7. Budz
    2,976
    45
    Mar 17, 2002
    Ashburn, Va USA
    It looks like you have two different style caps as well. The top pick looks like the cheaper Tawain repro style, and the second looks to be the second design GM 'non-raised' Bowtie cap.
    Some cap info here---> http://www.nastyz28.com/forum/showthread.php?t=100653
  8. Gary S
    21,439
    412
    As stated in post #2, there were actually 4 styles of these wheels during the 70-81 year run.
  9. Budz
    2,976
    45
    Mar 17, 2002
    Ashburn, Va USA
    Thanks Gary...edited. I'll wear my glasses next time....
  10. rsbad454
    101
    Sep 23, 2015
    NorCal
    These parts came on the car when I bought it. Learning new stuff everyday as I take a closer look and see what's different.
