z28 mystic wiring?
Discussion in 'Troubleshooting & Diagnosis' started by piru, Nov 10, 2005.
  1. piru
    piru New Member
    Nov 10, 2005
    finland
    what is that box under center console?(it is made by acdelco)two connectors with huge wiring harness lead out on engine bay trough that loose grommet on picture.third pic shows some of the watertight connectors on the other end of wires.i cant find these wires on any wiring diagram that i have found so far.:confused:
    car is 1980 z28
  2. Strange81Z
    Strange81Z Veteran Member Lifetime Gold Member
    5,945
    14
    Nov 29, 2001
    Amarillo, Tx
    Are you certain that it's an 1980? That looks like the computer that was first put into the Camaro in 1981. If that truely is an 1980, I have no idea what that could be....unless I'm mistaken and 1980 was the first year of the computer controlled emissions...:confused:
  3. piru
    piru New Member
    Nov 10, 2005
    finland
    yes,car is built in 1980 van nuys california vin is 1p87hal.it didnt come to my mind to look at this
    http://www.nastyz28.com/camaro/wire/81w-ecm.jpg
    wiring diagram cause it is for 1981 model,this is wery odd.i bought the car without motor so i had no idea where those wires should go,im now installing a 1979 350engine in so i think ill strip that wiring harness away.i have buildsheet for car and there is option numbers nb1 nb2 added.
    http://www.nastyz28.com/sbchevy/rpo-nt.html
    thanks for help!
  4. muscl car
    computer ECM is what that is
  5. Analog-kid
    Analog-kid Veteran Member
    270
    Oct 20, 2004
    Columbia SC
    An 81 could still have a 1980 build date ( late year). Could have been one of the first of the model year. Does the console have a open space at the front under the radio? If not it's an 81 console.
  6. Gary S
    21,119
    312
    If it was an 81, it can't be registered as an 80. That is illegal, so you can bet it is really an 80. NB2 is California emissions, and the 80 Camaro with NB2 had the computer that the other 49 states got on the 81. NB2 did include the ECM under the dash, and to make that fit, you would need the console used in the 81 models for the other 49 states.
  7. 1978LT
    1978LT Veteran Member
    16,280
    Feb 24, 2002
    Poquoson, VA USA
    I think California cars started the CCC setup in 1980. I'd check things out, because that's for sure an ECM ;)
  8. 80Camaroman
    80Camaroman Veteran Member
    2,675
    Nov 16, 2001
    Beavercreek, Ohio, USA
    Yes, GM started putting the ECM computers in all their 1980 cars that were equipped with California Emmissions. That is definetly an ECM pictured there. 1981 was when GM extended it to all their cars. I bet the harmonic balancer on the engine in your '80 Z28 does not have any timing marks either. This is another way you can determine if its a California Emmissions equipped car or not. Hope this helps! ;)
    Jim
    '80 Berlinetta
  9. Nick Gifford
    Nick Gifford Veteran Member
    806
    Aug 10, 2000
    Chelmsford, England, UK
    its been a while since i last saw my Chilton's manual, but I seem to remember there being two different systems between 80 and 81 - the 1980 being a Command Control Module, and the ECM arriving in 1981. I don't think the earlier version was a full management system...as for California only I wouldn't have a clue.
