z28 gas pedal
Discussion in '1970 - 1973 Specific' started by jax71z, Jan 24, 2015.
  1. jax71z
    jax71z New Member
    Jan 9, 2015
    eastlake ohio
    I Am Changing My Camaro Gas Pedal To Z28 Pedal And Wandering If My Stock Accelerator Rod And Linkage To Carb Will Have To Be Changed Out Also Any Of You Guys That Have Done This Or Know The Answers Your Help Would Be Appreciated Also Wandering If 70 And 71 Radiator Overflow Bottle Are The Same Thanks Guys! 1971 CAMARO Z28 CLONE 383 AUTO 373 POSI
  2. jax71z
    jax71z New Member
    Jan 9, 2015
    eastlake ohio
  3. ls777z
    ls777z Veteran Member
    2,098
    Feb 19, 2000
    Clay,NY
    Are you talking about the 70 Z floor mounted pedal or are you talking about something different ?
  4. l16pilot
    1,710
    86
    Dec 13, 2004
    Hurlock, MD, USA
    Jax - the throttle cable and throttle rod mount on the firewall are interchangeable between the standard hanging pedal and the 70/71 Z28 floor mounted set up. The throttle rod is unique and very different between the two and you are best off to find an original Z28 throttle rod and floor support bracket or a reproduction version to make it look and operate correctly.
    If your car still has the original floor boards, there are two factory "dimples" under the carpet that locate the two 1/4 holes for the bracket/ball studs. OPGI sells an excellent reproduction of the floor mounted gas pedal...search for 1967 gas pedal...that is correct in all details to the 70-71 gas pedal.
    Hope this helps.
  5. jax71z
    jax71z New Member
    Jan 9, 2015
    eastlake ohio
    thanks ls777z andl16pilot yes thats what I AM TRYING TO DO, REPLACE STANDARD HANGING PEDAL WITH 70/71 Z28 FLOOR MOUNT PEDAL ANY IDEAS WHERE TO FIND Z28 THROTTLE ROD OR STOCK RADIATOR OVERFLOW BOTTLE THANKS FOR YOUR HELP ! JAX71X 383 STROKER
  6. twozs
    twozs Veteran Member
    8,779
    159
    Aug 5, 1999
    hopewell jct ny
    the Z28 didn't have an overflow till 73 im pretty sure .
  7. COPO
    16,649
    333
    STOP iT wItH THE CAPS!
    Twos is correct, '73 was the 1st yr for the jug.
  8. l16pilot
    1,710
    86
    Dec 13, 2004
    Hurlock, MD, USA
    Occasionally, original components come up for sale on eBay, Craigslist and this site or you can purchase the individual components or a complete kit through my site www.2ndgenz.com.
  9. jax71z
    jax71z New Member
    Jan 9, 2015
    eastlake ohio
    sticking z28 gas pedal
    do 70/71 z28 floor mounted gas pedals have a problem sticking thanks for your help. jax71z
  10. COPO
    16,649
    333
    Never, and I've had my car for 34 yrs.
