z28 authentic or not
Discussion in 'Camaro Questions' started by pro z28, Nov 9, 2017.
  1. pro z28
    pro z28 New Member
    Jun 19, 2016
    summerfield, florida
    I have a 1970 Z28 Camaro,no indication on the cowl tag.
    The prior owner assured me that it is a real 1970 Z28.
    Is that possible?
  2. 70lt1z28
    1,582
    176
    Oct 3, 1999
    Beavercreek, Ohio, USA
    If its a Van Nuys built car, there wouldn't be a z28.10 (white Stripes) or z28.19 (black stripes) on the tag (after 1st week of April build). Only Norwood build cars got that on the TT. 1st week of April or before it would be just 28.10 or 28.19, again for Norwood cars only.
    LA (AKA Van Nuys) built cars are harder to tell. Many of those had build sheets on top of the gas tank or under the seats sometimes. Look for that.
    More can be found here:
    http://nastyz28.com/2gcog/stegmiller/cowl_tags.htm
    Post the tag and we can let you know more.
  3. FlaJunkie
    5,797
    55
    Mar 24, 2001
    Rockledge, Florida
    More info. What is the VIN? Motor pad numbers? Is the engine original? If so, there is a partial VIN by the oil filter on the block. Look up other 70 Z28 stuff here.
  4. pro z28
    pro z28 New Member
    Jun 19, 2016
    thanks very much for the info..very helpful... jeff
  5. pro z28
    pro z28 New Member
    Jun 19, 2016
    thanks very much for the info... jeff
  6. jimrr
    jimrr Veteran Member
    957
    190
    Jun 12, 2016
    sarasota
    Does your gas pedal pivot from the floor?
  7. Green hornet
    Green hornet Veteran Member
    1,074
    142
    Oct 11, 2015
    North Bay, CA
    Best thing to do is post a bunch of pics of the car. Members will be able to help you out better.
  8. badazz81z28
    14,279
    124
    Las Vegas, NV
    Documentation is the only real way with LA cars. Because of that, it's the only proof to ensure it keeps Z28 value.
    Anything on LA car can be faked.
