Z21 Style Trim Cars roof drip moulding?
Discussion in '1970 - 1973 Specific' started by nasblu, Sep 14, 2016.
  1. nasblu
    nasblu Member
    69
    Dec 5, 2009
    PA
    Is the side roof drip moulding around side glass on Z21 style trim cars the same on vinyl top cars and non vinyl top cars?
  2. l16pilot
    1,588
    75
    Dec 13, 2004
    Hurlock, MD, USA
    On the 70-73 at least, there were two different drip rail moldings depending upon whether the car had a vinyl top or not. The molding for the vinyl top cars was slightly wider.
  3. twozs
    twozs Veteran Member
    8,671
    130
    Aug 5, 1999
    hopewell jct ny
    73 was plastic
  4. l16pilot
    1,588
    75
    Dec 13, 2004
    Hurlock, MD, USA
    I thought that was a 74 or 75 thing..thanks for the correction.
  5. Gary S
    21,082
    308
    I don't know the exact years, but early years (70-72?) had stainless steel. Then, mid 70s had plastic, and the later second gens had aluminum gutters. They should all be interchangeable except that different ones fit cars with vinyl tops.
  6. CamarosRus
    CamarosRus Veteran Member
    I went out to the shop and checked my 73 R/S LT Vinyl Top Camaro.
    Looks like a satin aluminum, but I could easily bend outward the rear most edge and indeed appears to be PLASTIC !!
    Speaking of VINYL TOPS, how many of you, knew the material used was more "Shiny/Glossy" starting in 1972 !!!!!!!!!
  7. BillyDean7173
    BillyDean7173 Veteran Member
    650
    78
    May 21, 2014
    Hutto, TX
    That figures. Looks like another thing I'll be doing to my 73 that's not technically correct since I'll be using the stainless steel trim. I can't bring myself to use the plastic ones.
    Just like the Z28 decal on the rear spoiler. Can't do that either. I'll be using an NOS emblem the way GM should have done it on the 73s. It's not like there was a shortage of emblems. Cheap bastards.
  8. Peter Wilson
    Peter Wilson Veteran Member
    my 71 Z28 w/vinyl roof had plastic mouldings on it . Ive commented on this before when ive seen the plastic vs metal subject on here . my car is a very low mileage ex- racecar . it was taken off the road in 1972 after having been driven for the summer of 71 only . it was original paint when I bought it 9 years ago . Ive since repainted it and installed new vinyl on the roof . its taken me 9 years to find the original moldings which I just found this summer . my moldings were cracked on the A-piller where there was a factory seam in the vinyl . the same on both sides .
  9. 1971zed
    1971zed Veteran Member Lifetime Gold Member
    274
    11
    Aug 31, 2010
    Retired in Ottawa Canada
    My 1973 Type LT with vinyl roof had plastic mouldings.
    I bought the car new and the first summer I cracked one.
  10. Zstar
    Zstar Veteran Member
    1,208
    249
    Mar 23, 2014
    Ocala, Florida
    My 73 has the emblem on the short spoiler.
