Your Engine Specs and Data
Discussion in 'High Performance Modifications' started by vegas1974z28, Apr 22, 2010.
  1. trmnatr
    trmnatr Veteran Member
    650
    Apr 22, 2009
    Maryland
    400 we ran a while back, here is a quote where I posted the specs
  2. trmnatr
    650
    Apr 22, 2009
    Maryland
    The suspension has now been set up and has this engine,,,
    - 327 Small Block .060" over, fully modified block and filled with Hardblok
    - Bryant 4340 Billet 40 pound crank, knife edged with small rod journals
    - GRP aluminum rods
    - Ross custom pistons, cut for .031" ring pack with 1/16" second and ultra low oil ring tension
    - Custom ported iron heads with Ferrea hollow stem valves and NexTek springs with titanium retainers
    - Crane shaft rockers with 1.65" BBC pivot length, high ratios
    - 7/16" pushrod's
    - Solid Roller Camshaft ~ .800"+ lift
    - Jesel Belt Drive
    - Tunnel Ram with two carburetor's but also have fully ported single plane to match heads with Pro Systems XE1100 Domintor
    - Vacuum Pump
  3. fuzzy dice
    fuzzy dice Veteran Member
    651
    Apr 16, 2008
    Deltona, Fl.
    Year weight
    1981 Camaro
    3750 # with me in it
    Small tire..28x10.5x15
    Dyno numbers
    None yet
    Engine
    BBC 454 bored 40 to 465..one month old
    Forged top and bottom..full roller motor
    305 Aluminum heads
    .714 lift Comp Cam
    Studded and Girdled
    Transmission
    FTI Glide with brake and 1.80 straight cuts
    FTI 8" billet converter..5000 stall
    Quarter Stick w/ Shifnoid
    Rear
    12 bolt with full spool and 4:30 gears
    Moser 33 spline Axles with C clip eliminators
    Suspension
    Stock leafs..3-way shocks..Southside Machine Bars
    Moroso Trick Springs
    Sub Frame Connectors
    Times:
    So far in 3500 DA
    60' 1.50
    330' 4.50
    660' 7.04 @ 95.6
    Not enough tire and too much gear to run the 1/4
  4. Flextrainer
    Flextrainer Veteran Member
    565
    Sep 13, 2012
    Knoxville, tn
    Year weight
    1978 3659
    Dyno numbers
    None yet
    Engine
    396 sbc. Not in sheet. Heads cnc'd to 206 cc intake runner smallest was 198 biggest 201, pretty good. Bob weight lighter than stock 350.
    1-5/8 into 2-1/2" with x Dynomaxes.
    Transmission
    350 th. stock drum. Better sprag, clutches, steels. Extra pack, apply piston milled. Reprogrammed valve body and separator plate. Instant shifts. We'll call it a 2200 stall.
    Rear
    30 spline eaton, moser axles, 3.42 Richmond r&p.
    Suspension
    Bone stock,except sfc & body bushings, including worn out bushings, dealer installed air shocks.
    Times:
    Best et 7.59 1/8
    Best mph 97 1/8 all on 265/50-15 400+ tread wear street tires.
    Best 60' 1.77 same tires.
    Work coming over next two months.
    New front and rear suspension. Ptfb gt front/comp rear springs, adjustable shocks. Spherical bushings in front leafs. Slicks. Custom 9" converter around 3800 flash. Exhaust cut outs. Single plane intake, will know which tomorrow as I gave three choices to wife. Electric water pump and fan. About 100-150 pounds to be removed. Chassis bushings. New times coming in March.
  5. txfbodyfan
    txfbodyfan Veteran Member
    165
    Sep 18, 2014
    Mercedes, TX
    74 Camaro
    Year weight
    1974 Camaro
    3400 weight
    Dyno numbers
    Est. Engine Dyno numbers 650/600 FWHP
    (David Vizard duplicated design)
    Engine
    489 CI
    Studded 4 Bolt gen 4 Block
    Weisco Pro Tru Pistons 10.2 to 1 compression
    Eagle 4340 Crank
    Scat 4340 I Beams w/ ARP 2000 7/16" bolts
    Zamora Racing Heads Ported and Polished ProComp 300 CC Oval Port heads 2.25/1.88 valves
    Professional Products Ported and Polished Air Gap Style Intake
    Comp Cams Xtreme XR280R Solid Roller cam, Push Rods, Springs, and Stud Gridle
    Crower Roller Lifters
    Quick Flow 750 cfm w/ mechanical secondary’s (street carb), AED 950 w/ mechanical secondary’s (strip carb), and tuned HEI distributor.
    https://www.facebook.com/#!/video.php?v=684917681597233&set=vb.100002370226525&type=2&theater
    Exhaust
    Headman headers 2" pri 3" collectors......Pypes Complete
    Rear
    3:73 with 10 bolt Eaton Carrier
    Suspension
    Rear; Heidt’s 4 Link suspension w/adjustable Coil over Shocks, Heidt’s sub-frame connectors & 4 Point Roll Bar. Front; Moroso Trick Springs & Competition Engineering, various new bushings.
    Transmission
    Trans Depot “Destroyer” 700R4 rated for 700 HP, Precision Industries Vigilante 2800-3000 single disk converter, & cooler.
    Times:
    NTY
  6. LeKid
    LeKid Veteran Member
    434
    8
    Feb 5, 2006
    Winnipeg, MB
    I guess it is about time I put my combo on here, I guess I never did in the past!
    1980 Camaro
    3250 race weight
    Dyno numbers
    669hp - 581ft/lbs on the engine dyno N/A
    Engine
    Block: Dart Little“M” block with billet caps 4.125bore, 350 mains
    Crank: Eagle 3.75 stroke 4340 forged crank
    Rods: Eagle 4340 6in. H-Beam with ARP2000 bolts
    Pistons: JE Nitrous Series 3cc small dome - 12.5:1cr
    Rings: Total Seal Rings with Hell-Fire top ring
    Bearings: Clevite H series
    Oil pump: Melling High flow
    Oil pan: Milodon Stroker Pan
    Timing chain: CompCams Billet with trust washer
    Balancer: ATI 7" steel
    Cam: Dave Crower custom nitrous cam 0.688/0.648 - 298/308adv - 264/274@0.050 with 112lsa - CompCams 999 sptings and Crower 0.085" higher retainers
    Lifters: Crower Solid Roller with HIPPO oiling
    Heads: Dart Pro1 215cc ported by Mike Stark @ CFM - 320cfm@0.700
    Rockers: Yella Terra Platinum twin-shaft rockers 1.6in 1.5ex
    Push rods: Manton 3/8" 0.120" wall
    Intake: Dart single plane ported by Mike Stark@CFM
    Carb: AED 950cfm HOM
    Headers: Hooker Super Comp 1 7/8" - 3 1/2"
    Fuel pump: Holley Dominator 350gph with stock tank and rear sump
    Ignition: MSD 7535 box with HVC coil and Taylor 10.8mm wires
    Nitrous/
    Edelbrock Performer RPM II system flowed by Steve Jonhson at Induction Solutions
    Running a 275hp nitrous shot (93 nitrous jet)
    Exhaust
    3.5" x-pipe from Torque tech
    Shoenfeld 3.5" bullet mufflers
    Rear and weight movement
    Moser M9 9" with Strange Aluminum center section with 33-spline axles and 3.70 gears
    Suspension
    Front: Smith Racecraft control arms with Moroso springs ans AFCO DA re-valved by Jason@AFCO
    Rear: Calvert Split-mono with Caltracks and Rancho 9-ways
    Wheels and Tires
    Front: Champion Speed Series 15x3.5 with Hoosier Front runners 27" tall
    Rear: Champion Speed Series 15x10 with 5.5bs with M/T 275PRO
    Transmission
    TH-400 with TCI 2.10 gear set and Red Alto clutches
    Trans-Specialties Trans-Brake valve body
    Trans-Specialties 9.5" 900XHD Converter
    Times:
    1.266 - 60ft
    5.70@122mph - 1/8 mile
    8.94@151.8mph - 1/4 mile
  7. MR NICE
    MR NICE Member
    59
    Feb 5, 2013
    det mi
    1978 Camaro
    weight ?
    Engine 454 LS7
    13 to 1 compression
    decked block
    balanced
    all forged lower end
    7qt pan
    fluid damp
    Comp Solid flat tappet ZL1/LS7 camshaft
    Solid lifters with oil holes
    Comp 930 springs
    990 heads milled stock
    Crane gold rockers
    Victor jr intake
    Quick fuel 950 e-85 carb
    Hooker super comps 21/4 3.5"
    Ignition
    Msd 6al msd dizzy& coil
    Trans
    400 turbo upgraded sprag 4200 stall freakshow convertor,large stack plate cooler
    Rearend upgraded axles 10 bolt 373,perfect launch cover,forged input
    yoke,arp carrier studs,1350 ujoints 3" driveshaft
    10point cage/full interior,ps/pb electric pump.
    Fuel system all braided quick fuel 175 pump,12 gal fuel cell/trunk mount battery
    no times yet
  8. 1985 Z28
    3250
    377 604 HP
    Turbo 350
    4.56 7.5
    10.03 @ 131 @ 2700 DA NA
  9. lapedr
    lapedr Veteran Member Gold Member
    525
    Jan 28, 2003
    Pembroke, GA
    Year weight
    1972 Camaro Sport Coupe
    3775 curb weight with options
    Dyno numbers
    No dyno
    Engine
    1974 Chevy C20 350 4 bolt main block bored .040 = 385 CI
    10.49 : 1 compression
    1970 GM 186 heads with 2.02 / 1.60 valves port matched to intake manifold
    Weiand X-Celerator Intake Manifold port matched to heads
    750 Holley DP
    Edelbrock Performer RPM cam
    Exhaust
    Headers and Flowmaster 2 1/2in exhaust
    Rear
    Rebuilt 3.73 GM 10 bolt
    Lakewood traction bars
    Suspension
    Stock
    BF Goodrich P245/60R15 Radial T/A's
    Transmission
    Rebuilt Turbo 350 with TCI kit, 2000 RPM TCI stall convertor
    Times:
    Unknown
  10. dman79z28
    dman79z28 Member
    34
    Sep 11, 2011
    Chaffee Missouri
    1980 Pro street Camaro with 540 BBC
    874 Hp
    Lunati Light weight crank with JE 11.2 forged pistols
    Ported GM 410R aluminum race heads.
    Not sharing cam spec. SORRY!!!
    Edelbrock tunnel ram intake with 750 Quick Fuel carbs.
    Holley roll control.
    Coan 400 Trana with 4000 stall.
    Fab 9 rear end with Coni coil over adjustable shocks.
    4.30 gears,
    Full chrome molly chassis and roll cage
    Mickey Thompson 18.5 x 31 tires.
    Not raced yet!!! But ready!
