Work/welding table
Discussion in 'Garages, Workshops & Tools' started by sponge003, Sep 16, 2012.
  1. sponge003
    sponge003 Veteran Member Gold Member
    1,511
    Jan 10, 2009
    Concord, NC
    Built a welding table this past week
    3/8" Plate top
    1 3/4" pipe legs
    1 5/8" Cross bars
    2" reciever style mounts for tools/vises at every corner
    I used the pipe for legs and cross bars so I could do some notching and welding prior to converting my 6 point cage to 12 point.
  2. bitchin'71SS
    bitchin'71SS Veteran Member
    397
    Sep 10, 2009
    Poughkeepsie, NY
    Awesome, thanks for sharing I'll be building one in the near future as well
  3. sickfast1964
    sickfast1964 Veteran Member
    442
    12
    Aug 26, 2012
    Corinth, Tx
    very nice looking welds.... that must be your first try at Mig welding lol
  4. Marks71BB
    Well done!
    Looks nice and sturdy with good penetration.
    I think I might have made the vertical receivers flush with the table top. They might get in the way. You can always cut em off if that's the case.
  5. 5spd540
    12,339
    11
    Sep 19, 2009
    Guyton, GA
  6. sponge003
    1,511
    Jan 10, 2009
    Concord, NC
    Yes it is, probably 200+ pounds but it slides around quite easily
  7. sponge003
    1,511
    Jan 10, 2009
    Concord, NC
    I thought about that and decided to have them up 1/2", no real reason behind it.
  8. John Wright
    13,986
    51
    Aug 9, 2002
    Rustburg, Va
    Not sure how level/flat your floor is, but you can use some 1/2" or 5/8" dia nuts tack welded over a hole in some flat bar, weld them to the bottoms of your legs, then thread in some bolts to use as levelers. If the heads of the bolts are digging in to the floor, then tack some flat bar to the heads of the bolts for the feet.
  9. sponge003
    1,511
    Jan 10, 2009
    Concord, NC
    Good idea!!
    Trying to get it to not have a little wiggle to it is impossible as the floor changes a little around the shop.
