wire harness compatibility
Discussion in 'Tips 'n' Tricks Topic' started by 71 in pieces, Feb 12, 2004.
  1. 71 in pieces
    71 in pieces Veteran Member
    282
    Jul 24, 2003
    newton, iowa, usa
    are the wire harnesses for the 71 camaro without guages the came as one that has guages? any help would on this would be great.
  2. reinhardt79
    reinhardt79 Veteran Member
    853
    May 12, 2002
    VA BCH, VA
    first, i think u got the wrong section. that probably y u aint gettin many replies.
    i assume u wanna know so that u can swap the gauge cluster from a gauges model into ur idiot lights model. am i right? if so, then i know the answer for a 79. not sure if it is the same as a 70. the gauges cluster can be swapped over w/ some wires being swapped.
    look in the interior section.
    -Benjamin
    Virginia Beach, VA
    Working at a junkyard only pays me $8/hr, but the 50% off parts and all the crappy gas i can pump makes up for it.
