Wipers - Schematics?
Discussion in 'Troubleshooting & Diagnosis' started by steelwindmachine, Nov 22, 2002.
  1. steelwindmachine
    steelwindmachine New Member
    18
    Jul 23, 2002
    Manahawkin, NJ, USA
    1978 TA:
    Anyone have the wiring schematics for the wipers circuit?
    When I plug in the 2-pin flat connector on the front of the wiper motor, with the car in run, the wipers stay on even if the switch to them is off. They also don't return to their physical off position unless you play with the switch in the car on the dash.
    - Dan G.
    1987 Buick Turbo Regal
  2. Rick's Z
    Rick's Z Veteran Member
    366
    Jun 27, 2001
    Dover, DE
    sounds like a bad wiper switch. They can be repaired, just pull it out take it apart carefully clean all the contacts and reinstall.
  3. steelwindmachine
    18
    Jul 23, 2002
    Manahawkin, NJ, USA
    this is for a friend's car ... and I've tried before to get into the dash cluster.
    how do you remove the face-plate that goes over the gauges?
    - Dan G.
