wiper motor
Discussion in 'Tips 'n' Tricks Topic' started by dustinak31, Jan 25, 2011.
  1. dustinak31
    dustinak31 New Member
    Jan 24, 2011
    shreveport, la
    what is the problem if i unplug my wiper motor switch but the wipers still stay on. when i turn ignition off they return to normal. is it the switch or the motor????
  2. Vsolo
    Vsolo Veteran Member Lifetime Gold Member
    821
    10
    Sep 20, 2009
    So Central PA
    I will say it it the motor, mine did this 100 years ago (well late 70's) I did not know better & ran a switch to ... I forgot where sorry. and ran it that way for years.
    Later on I took the switch out & found out it was not the switch, it is pretty much bullet proof and well made, very simple too. Finally got a new motor. The hard part was matching up the washer assembly afterwards,
    You can get the washer assembly now pretty easy too. I got my new wiper assy from Pep Boys in maybe 1982 ? it still is running today
  3. greencamaro1981
    greencamaro1981 Veteran Member
    604
    Jun 2, 2010
    Montana
    yup motor likes to get dirty and screw stuff up
  4. harleymac
    harleymac Veteran Member Lifetime Gold Member
    125
    Oct 9, 2010
    decatur il
    the other thing to check is make SURE your switch still has a good ground on the dash panel . when my wipers did that it was the ground
