Winter is comming
Discussion in '1978 - 1981 Specific' started by Glava, Nov 9, 2017.
  1. Glava
    Glava Veteran Member Lifetime Gold Member
    327
    Mar 23, 1999
    Central NY
    Winters coming... finally put the Camaro up on jack stands and took off the factory rims to sand and repaint. From day one you could almost see through a lot of the paint on the rims.
    About 7 years ago I did a fresh up on the rims, but for some reason the paint has started lifting and cracking in the corners of the spokes.
    I'll finish getting these all sanded, crank the heat up to 70 in the garage and then prime & paint them -I don't want to do too good a job, because the Z has all original paint and if these look too good -they won't match LOL
    Z28 rear tire off.JPG Z28 sanding rim.JPG Z28 front tire off.JPG Z28 sanding rim2.JPG
