Will the big cap HEI dizzy drop in?
Discussion in '1970 - 1973 Specific' started by jimrr, Feb 28, 2017.
  1. jimrr
    jimrr Veteran Member
    937
    173
    Jun 12, 2016
    sarasota
    My 73 camaro with the engine in tge car? Or will it hit the firewall going in? Thx.
  2. wiseryder
    1,949
    19
    Sep 11, 2004
    belding,mi USA
    I have a big cap in mine
  3. Twisted_Metal
    25,447
    344
    It will drop in.
    If you have a factory air cleaner for a small distributor (points).... It will interfere with the big cap.
  4. jimrr
    937
    173
    Jun 12, 2016
    sarasota
    Yup getting rid of the points, don't care about the air cleaner. Just wanted to make sure it would drop in without removing the engine. Thx. Gents....
  5. Zspoiler
    Zspoiler Veteran Member
    Just use an MSD distributor .It uses a Ford style trigger. same clearance as you stock distributor,
  6. Green hornet
    Green hornet Veteran Member
    1,072
    141
    Oct 11, 2015
    North Bay, CA
    Big cap fits with no problem.
  7. BonzoHansen
    You will need to get it 12 volts. Your car would have a resistor inline.
  8. Twisted_Metal
    25,447
    344
    I just revisited this thread to add that "pointless" point of resistance.
    Replace the wire which feeds the HEI.
  9. jimrr
    937
    173
    Jun 12, 2016
    sarasota
    I was just going to bring it power to the power terminal in start and run. Was thinking about using the coil power wire. ?
  10. jimrr
    937
    173
    Jun 12, 2016
    sarasota
    Can I use the coil positive wire to power the new dizzy?
