Will at '79 Pulse Wiper Switch work on a '78?
Discussion in 'Electrical Systems' started by w10085, Oct 26, 2017.
  1. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,736
    65
    Aug 18, 2003
    On Wisconsin!
    This is what the 77/78 switch (you are looking for) looks like 77-78 wiper switch.jpg
  2. CAMeeks
    CAMeeks Veteran Member
    636
    23
    Jan 5, 2014
    Deer Park, TX
    I would like to bench test my switch. Is there an easy way?
  3. w10085
    w10085 New Member
    26
    Oct 28, 2015
    North Carolina
    Thanks for the picture Green 1977. Good question CAMeeks.
  4. Coadster32
    1,487
    87
    Oct 2, 2013
    Milford,CT
    Yes, you can bench test it with a multimeter set to ohms. You need the schematic to verify what each wire does as a guide.
  5. Coadster32
    1,487
    87
    Oct 2, 2013
    Milford,CT
  6. Zspoiler
    Zspoiler Veteran Member
    2,788
    171
    May 6, 2012
    Federal Way, Washington
    Have you checked 1978-87 "G" bodies .Malibu`s El Camino .,etc.
  7. junkyardZ28find
    770
    Mar 4, 2012
    des moines, iowa
    I bet a truck/van switch would work if you metal epoxied the tabs to the NOS switch. If the old one doesnt work cant hurt to try...I have a van one if you cant source a Camaro one-its 1977 only for the trucks but the wiring colors are the same-connector is different but you can change the leads around. Just a thought.
