Will a Holley Hi-Ram fit?
Discussion in 'High Tech Retrofits' started by SS Performance, Feb 27, 2017.
  1. SS Performance
    SS Performance Veteran Member
    139
    19
    Nov 17, 2016
    Has any one installed a Holley Hi-Ram in a 2nd gen Camaro?
    I'm getting ready to install a bored & stroked LS2 in my 70. I want to know if the Holley Hi-Ram will fit with a flat hood, cowl hood or some other hood.
    Thanks
    Craig
  2. Madmike72
    Madmike72 Veteran Member
    243
    Nov 26, 2010
    Walpole Massachusetts
    I think it's safe to say it will not fit under the stock hood. I know the mid-ram fits under a 2''cowl. I'm not sure about the high ram. I've done a lot of measuring on my own car with a 2''cowl and it may fit but will be very close. I have a ls truck intake (also 10''tall) and it fits but its really close because the hood tapers down towards the front.
  3. SS Performance
    139
    19
    Nov 17, 2016
    That's pretty much what I thought I just wanted to ask. I have heard that using the big block engine frame mounts will lower the engine about an inch. Also I am using LS7 heads and I think the LS7 Hi-Ram is a little shorter than the LS1.
    I already have the Hi-Ram left over from a project that wasn't completed so I will try it.
    Thanks for your help.
    Craig
  4. Madwhip
    Madwhip New Member
    15
    Jan 25, 2016
    Christchurch
    Hey Craig,
    Did the Hi-Ram fit with the 2" cowl?
  5. SRGN
    SRGN Veteran Member
    574
    180
    Feb 20, 2009
    Central NJ
  6. WASyL
    WASyL LS1 Bandit
    21
    17
    Nov 9, 2013
    Warsaw, Poland
    Can you send me some pictures of your under the hood?
    Best regards
