Who actually makes QUALITY drill bits??
Discussion in 'Garages, Workshops & Tools' started by 76_TypeLT, Jan 26, 2011.
  1. 76_TypeLT
    6,385
    132
    Jul 26, 2008
    Houston, TX
    I got some Bosch drill bits a while back and even though I knew they were made in China, I figured Bosch had a handle on quality control. Well, these drill bits are basically junk. Several bits have broken (not small bits either) and a few others can't drill worth a damn.
    Soooo, who still makes quality drill bits? Or did I get a bad set?
  2. sooner
    sooner Veteran Member Lifetime Gold Member
    1,414
    Mar 11, 2009
    Perry,Ok
    Nachi makes great drills and they stay sharp for a really long time. Can be a bit pricey though.
  3. 76_TypeLT
    6,385
    132
    Jul 26, 2008
    Houston, TX
    I've never found a good set of drill bits, not even some mid level bits that stay sharp for a few years. Maybe I expect too much from my drill bits.
  4. screamindemon
    screamindemon Veteran Member
    You have to buy cobalt drill bits if you want the best
  5. olstyle
    olstyle Veteran Member Lifetime Gold Member
    8,649
    Jan 27, 2008
    Crestwood IL.
    I bought a set of Dewalt pilot point tip, 1/16" to 1/2" when I started my camaro. All still cut good except for the 1/16 and 1/8 which broke or bent(my fault).
    Over all a good set of bits that won't break the bank.
  6. 5spd540
    12,339
    10
    Sep 19, 2009
    Guyton, GA
    I use only colbalt
  7. 76_TypeLT
    6,385
    132
    Jul 26, 2008
    Houston, TX
    is cobalt a brand or does this refer to the coating on the bits?
  8. frankz
    frankz Veteran Member
    2,057
    Aug 24, 2009
    Illinois
    Cobalt is an element used as an alloying agent to impart heat and wear resistance. It is also a brand name for tools sold at Lowes FYI
  9. screamindemon
  10. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    I'm convinced nobody does.
    My father in-law gave me a bunch when they moved that are from his tool and die days back in the 70's. Now those are some great bits! Night and day difference.
