Which 350 block should I look for?
Discussion in 'Engine Topic' started by BeefTip, Dec 11, 2010.
  1. BeefTip
    BeefTip Veteran Member
    722
    Aug 11, 2007
    Phenix City, AL
    eww...what do you have to do to make them support a bigger spring?
  2. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    If you look at the top there's a sticky that will tell you anything you want to know about Vortec heads, and engines they came on.
  3. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    A 3/4 ton or bigger truck will have 4 bolt mains.
    But yes ANY 96 and newer Vortec 5.7L is a good purchase.
  4. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    oem roller, 4 bolt, like the mod said read the sticky at top of the engine topic page.
  5. AJ_72
    AJ_72 Veteran Member
    5,122
    Jul 3, 2003
    Chebanse, IL USA
    I lucked out and got a 350 block out of a '90 Heavy 3/4 ton. Roller cam provisions, hole for the fuel pump rod, and 4 bolt main caps.
    Yeah BABY!! ;)
    Casting number
    14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
    This block was also used a lot in the "F" and "Y" bodies. There's a rumor going around that Corvettes got 4 bolt mains. I don't know if that's true or not, but I wouldn't count on it. The 4 bolts were mainly used in heavy duty applications.
  6. BeefTip
    722
    Aug 11, 2007
    Phenix City, AL
    thanks guys, i just saw the sticky up top!
  7. MyBoTy
    MyBoTy Veteran Member
    1,567
    9
    Feb 9, 2002
    Lubbock, Texas USA
    One other thing to check - some came with a mechanical fuel pump boss, some didn't. Even those that had it weren't all drilled, double check that - IF you're going to be running a mechanical fuel pump.
  8. BeefTip
    722
    Aug 11, 2007
    Phenix City, AL
    good tip! However, at this time I would probably just use my electric fuel pump thats already setup on the car.
  9. z28rod
    4,472
    Apr 30, 2009
    I never knew this, thought it was only on the bbc engines.
