Where to locate the rear light grounds?
Discussion in 'Electrical Systems' started by stapleszoo, Jan 2, 2018.
  1. stapleszoo
    stapleszoo Veteran Member
    108
    May 1, 2011
    Glastonbury, CT
    Hi
    Finally getting to wire up the rear lights on the 80 Camaro (5yr build)- where do you locate the rear light harness ground? I have one with a odd looking terminal and another (from digitails) that I will need to locate. Are there exterior mounted grounds or are they supposed to be inside the trunk? The schematics does not really give a location terminate these.
  2. Twisted_Metal
    25,749
    442
    My 80 has the ground terminal attached to the upper rear of the raised rib on the driver's side of the trunk floor.
    I'm pretty sure that is the factory location.
  3. stapleszoo
    108
    May 1, 2011
    Glastonbury, CT
    that helps alot- thanks
