Wheel info for anyone interested....(Chuck)
Discussion in 'Original Drivetrain Topic' started by Budz, Apr 11, 2004.
  1. DANZ
    DANZ Veteran Member Lifetime Gold Member
    798
    Feb 28, 2004
    Purcellville,Va.
    ....Other than the spare, I'm not expecting ANY Top notch resto Z to be pulling a Trim Ring for inspection.....so I'll take the spare for all five as correct...Chuck[/B][/QUOTE]
    Why would you have to pull the trim ring off? Aren`t we talking about the hole thats on the out side part of the wheel?
    Dan
    70 RS Z28
  2. Gary S
    20,959
    269
    [/B][/QUOTE]
    Yes, that is the hole we are discussing, but I think Chuck is taking it one step further. He probably means that the date code wouldn't be visible unless the trim ring is off, and these rings aren't something that can be easily removed.
    Step one would be to get wheels with the correct hole size for your car, and then if possible to match date codes too.
  3. DANZ
    798
    Feb 28, 2004
    Purcellville,Va.
    Gotcha, I understand......THANKS
    Dan
    70 RS Z28
  4. COPO
    16,248
    239
    My 70 May Norwood rim is AU 21 4 K10. The 5/8 and 13/16 is that the height or width of the oval? Mines 1" x 5/8 wide.
  5. CamarosRus
    CamarosRus Veteran Member
    COPO, Without seeing your wheel, your numbers are in reverse order from what I'm used to seeing...........I'm thinking that wheel is 4th month (April) 21st day 1970 at Kelsey Hayes #1 plant location...............
  6. 70COPO
    70COPO Moderator Lifetime Gold Member
    1,085
    13
    Dec 28, 2003
    Chillicothe Ohio
    I have 13/16" oval / GM D / K10 6 1 AU 70 June 1 on my 06D Norwood build.
  7. CamarosRus
    Thanks to ALL for new contributions to wheel "hole" size and dating.....PLEASE INLCUDE plant where your car was built along with car build date AND wheel info so "someone" can add to Dans data base..............
  8. COPO
    16,248
    239
    I read the #'s off from left to right.
  9. Budz
    2,919
    34
    Mar 17, 2002
    Ashburn, Va USA
    That match's the 5th wheel on my list at the beginning of this post....
  10. COPO
    16,248
    239
    Photo 1970 Z28 April 21 for my 05E May car.
