What's the easiest way to get under 13secs?
Discussion in 'Camaro Questions' started by BOWIE, Dec 24, 2007.
  1. Marks71BB
    Put a big block under the hood and the old block in the trunk for added traction;)
  2. Toomanyhobbys
    Toomanyhobbys Veteran Member Lifetime Gold Member
    2,807
    Apr 12, 2005
    Mesa, AZ
    Oh sure Mark, get him into a pigblock and what next tube doors?
  3. blades67
    blades67 Veteran Member Lifetime Gold Member
    1,542
    Oct 22, 2005
    Chandler, Arizona, USA
    There's no reason you couldn't rebuild your original motor. A good machinist could deck the block without removing the stamped numbers and you could also have the block converted to four bolt main caps if you wanted to. I don't think you need to unless you want to try for more than 500 horsepower or you plan to spin it more than 6000 rpm. Even at that there are some old tricks that will let the engine live at 600 horses without four bolt main caps like machining the caps flat and bracing them with half inch square stock and studs with an align hone to keep everything square. Again, not something you need to do, just what can be done.
    I'm also local, so when Jerry gets mad and his butt fur is all knotted up you can also call me.;) :p :D
  4. BOWIE
    BOWIE Veteran Member
    327
    Nov 11, 2007
    Scottsdale, AZ.
    Already there. Candy-striped tube doors for the holiday season! ;)
  5. Toomanyhobbys
    2,807
    Apr 12, 2005
    Mesa, AZ
    Blades we can both"help" him out and get him completely confused
  6. Marks71BB
    But of course!!!
    Its the natural progression of life right?
    big block, tube doors, thirty pack with two bi chicks....
  7. Toomanyhobbys
    2,807
    Apr 12, 2005
    Mesa, AZ
    Duh what a blatant loss of any sanity I had !!!!:screwup:
  8. Marks71BB
    It was a Levi reference Jerry
    Happy new year:)
  9. andrew1977
    andrew1977 Veteran Member
    1,499
    Oct 1, 2006
    parksvegas, BC
    this is funny.. when i asked how fast my car would be people on here said my 420-450 hp 3400 pound camaro with 150 shot of N20 would run mid twelves... and my suspension isnt stock... comparing to other people on here i may be in the high 11s.. or faster...
  10. hucks 70
    hucks 70 Veteran Member
    1,293
    Jun 4, 2004
    millstadt ill USA
