What's a good wheel cleaner?
Discussion in 'Tips 'n' Tricks Topic' started by titletowncards, Aug 5, 2014.
  1. titletowncards
    titletowncards Member
    34
    Jun 19, 2013
    Antigo, WI
    Need some advice on a good Wheel/Rim cleaner.
    They get really dirty real fast. Any good one's out there that are fairly simple and do a good job of course. :)
    Got these:[​IMG]
  2. BARNFIND
    BARNFIND Veteran Member Lifetime Gold Member
    309
    Oct 20, 2007
    GPS WENT DEAD...LOST
  3. rockheadrocks
    rockheadrocks Veteran Member
    My son and his friends do a pretty good job, but I don't think that's exactly what you're asking.
  4. titletowncards
    34
    Jun 19, 2013
    Antigo, WI
  5. titletowncards
    34
    Jun 19, 2013
    Antigo, WI
    Bring them over! :cool:
  6. Odin
    Odin Member
    40
    Sep 15, 2003
    Sadly, I don't think you'll find anything that will make those wheels look better than some aluminum polish and lots of elbow grease.
    I was using the Meguire's wheel cleaner on my truck but had a bad experience with it last year. From now on I think I'm going to just stick with the soap that I use on the paint.
  7. grzewnicki
    I usually use Simple Green, 50/50 mix.
  8. fbody_mike
    fbody_mike Veteran Member
    If it is bare aluminum I would only use aluminum polish like the Mothers in a can. You can then put some Carnauba after to help it last a little longer. I think most of the wheel cleaners on the shelf are meant for coated wheels, like the OEM wheels are done. Meguairs has a cleaner spray for bare aluminum, but I found it is not better than car wash soap and water.
  9. titletowncards
    34
    Jun 19, 2013
    Antigo, WI
    Good stuff so far! It is bare aluminum and I think ur right about most cleaners. I've found that some leave a film on afterwords. The Carnauba is a good idea.
  10. David79Z28
    1,277
    39
    Oct 22, 2009
    Greenville, TX
    I just use regular car soap in my uncoated wheels .
    I clean them more often than my cars with coated wheels to reduce any build up that would require any type of cleaner.
