What will she run
Discussion in 'Competition Camaros' started by Justin79maro, Nov 14, 2016.
  1. Plant Engineer
    Plant Engineer Veteran Member
    348
    72
    May 17, 2017
    Washington State
    Shift manually 1st to 2nd. Leave 3rd for the drive home. Your ET will benefit. It probably wont affect your trap speed.
  2. Justin79maro
    Justin79maro Veteran Member
    131
    Jan 15, 2015
    Bonne terre, missouri
    What rpm do you think I should be shifting from1st to 2nd?
  3. Plant Engineer
    348
    72
    May 17, 2017
    Washington State
    Depends on your cam really. If you are making peak HP at 6000 then shift about then.
  4. mrdragster1970
    I was always taught you try to shift ~1000 RPM above peak HP if the bottom end can handle it??
    If not you sacrifice ET for not blowing the crank out the bottom!!!!!
  5. 76z28
    76z28 Veteran Member
    1,717
    Jun 29, 2009
    bakersfield
    I would think a couple hundred after peak due to helping it stay in the rpm band
  6. Plant Engineer
    348
    72
    May 17, 2017
    Washington State
    True but I wouldnt eant tobe the guy twisting a 383 to 7 grand. Really depends on the cam and where the powerband peters out.
  7. 76z28
    1,717
    Jun 29, 2009
    bakersfield
    Psh I spun my big block to 7, that 383 will live
  8. mrdragster1970
    And I shifted my BBC at 9250!!!!
    Giant heads, giant tunnel ram, giant cam, billet cranks & rods and small inches makes the power band sky high.
  9. 76z28
    1,717
    Jun 29, 2009
    bakersfield
    De
    Define small ;-)
  10. Plant Engineer
    348
    72
    May 17, 2017
    Washington State
