What size and offset for front "skinny" tire?
Discussion in 'Competition Camaros' started by 54baker, Oct 18, 2017.
  1. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    I'm going to be running a MT 3754x 275/60r15 (28.2 x 11.4) drag radial in order to stay classified as a small tire... I am told that a 10x15 rim with 5.5 backspacing will work with this tire on an 81 with stock width rear end. (please correct me if i've been misinformed here...). Now I don't know what rim and tire to run in the front. (wheel size and offset, and tire size and type). 3600 pound camaro....13sec car. Also, would you recommend this rear tire for almost all strip use?
  2. rustorbust
    rustorbust Veteran Member
    226
    Dec 14, 2009
    San Diego
    I'm pretty sure mine on the front of my car are 15x4 with 1.75" backspace.
    54baker likes this.
  3. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    I just noticed that the rear tire I'm talking about suggests a 9.5" wheel width? I'm thinking most wheels are 10"... I was planning on getting a 10". The tire section is 11.4" and the tread is 9.5".
  4. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    OK. Thanks. What tire are you running?
  5. HawkX66
    HawkX66 Member
    84
    22
    Sep 20, 2017
    MI/MA
  6. mrdragster1970
    Be careful with those rear wheels.
    I have a stock width rear end and a 10x15 @ 5.5 won't fit, I'm at 4.5".
    Don't worry about mounting them, we run a 10" tire on 15 x 15 all the time.
    It works just fine.
    The fronts are the fronts, whatever style you like works fine.
    The tiny bit of difference in BS doesn't make any difference on our cars.
    3.5 or 4", all fit any front runner with zero issues I've ever heard about.
    Good luck.
  7. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    Most of the guys I've talked to said 5 to 5.5 bs for a 10x15 and 4.5 bs for an 8 x 15 wheel.... Hmm. What did yours hit? the seat belt area? the leaf spring? So your'e saying that a 10x15 with a MT 3754x 275/60r15 (28.2 x 11.4) drag radial would fit better... without rolling the quarter?
  8. 54baker
    54baker Member
    89
    Oct 29, 2014
    Waverly, ia
    Thanks! looks good. What size tire is that?
  9. muscl car
    54baker likes this.
  10. muscl car
    I'm running 15x8 Weld Drag lites with 4.5bs mounted on a M/T 275/60 15 drag radials and they fit perfectly and it handles all the abuse my R/foot gives it on launches
    54baker likes this.
