what should i use?
Discussion in 'Body Restoration' started by tims78camaro, Jan 29, 2018.
  1. tims78camaro
    tims78camaro Veteran Member
    580
    Aug 6, 2008
    louisville ky
    getting ready to put my lower cowl on what should i put on the inside of firewall since i will never be able to coat it again
  2. bodymanbill
    bodymanbill Veteran Member
    1,022
    300
    Feb 1, 2007
    South Park Pa
    Get yourself a good weldthru primer and spray all your areas you will be welding, anything inside that isn't right by the spots being welded u can coat those with por 15 or chassis saver , I like to use epoxy primer though. When your finished get some cavity wax and shoot it anywhere it will reach until it runs out the bottom
    PalmbchZ28 likes this.
  3. xten
    xten Veteran Member
    2,084
    1,015
    Sep 24, 2014
    Pittsburgh, Pa.
    If you're using POR 15 or Chassis Saver, WEAR GLOVES!!! lol
    bodymanbill and jimrr like this.
  4. mark wagner
    mark wagner Veteran Member
    2,125
    18
    Jul 31, 1999
    Saylorsburg Pa. USA
  5. 70lt1z28
    2,630
    391
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Too each his own, but I'm not a big fan of the POR15 stuff. Get rid off the rust and epoxy prime. Southern Polyurethane (SPI) is well known and highly regarded by the resto community.
