What is this?
Discussion in 'Troubleshooting & Diagnosis' started by GPN, May 10, 2017.
  1. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    IMG_0309.JPG IMG_0308.JPG can anyone identify? Found under dash near fuse box while tracing wiring.....79 Z28
  2. Green hornet
    Green hornet Veteran Member
    1,023
    133
    Oct 11, 2015
    North Bay, CA
    I believe that is the clutch pedal neutral safety switch.
  3. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Tnx. Car running fine without it. Thinking to just leave well enough alone. Thoughts?
  4. twozs
    twozs Veteran Member
    8,480
    86
    Aug 5, 1999
    hopewell jct ny
  5. 351maverick
    351maverick Veteran Member
    3,058
    144
    Aug 11, 2010
    erie, PA
    car could start in gear...I've had that happen & it's SCARY
  6. GPN
    GPN Veteran Member
    115
    Oct 5, 2016
    Ok, tnx. Not really sure how it works. But I'll get new one & got it from there
  7. twozs
    8,480
    86
    Aug 5, 1999
    hopewell jct ny
  8. Green hornet
    1,023
    133
    Oct 11, 2015
    North Bay, CA
    As others have stated, without it the car can start if the clutch pedal is not pressed.
  9. badazz81z28
    14,177
    110
    Las Vegas, NV
    How would it start without it? If its disconnected the circuit is broken to start....
    I'm looking for one of these...Where can I get one and how does it bolt to the pedal?
  10. twozs
    8,480
    86
    Aug 5, 1999
    hopewell jct ny
    When someone jumps it out because they are stuck or can’t find one . I had a picture up but with the whole Photobucket thing ..
