What is this (in steering column)
Discussion in 'Troubleshooting & Diagnosis' started by Chuck71RS, Mar 14, 2017.
  1. Chuck71RS
    1,132
    38
    Nov 24, 2012
    Houston, Texas
    The copper (brass) part in the upper right, in my 1971 Rally Sport. Non-tilt steering column.
  2. Twisted_Metal
    25,980
    504
    I believe that is the key buzzer contact.
    (Lets you know you left your key in the ignition.)
  3. jlsug
    jlsug Veteran Member
    302
    9
    Apr 10, 2012
    iowa
    Twist_Metal got it right. Be careful if you pull it out there is a flat tension spring that keeps it tight, the spring can fall down in column upload_2017-3-14_9-17-53.jpg
  4. mich2112
    mich2112 New Member
    17
    May 27, 2006
    Williamsburg, VA
    True that...mine just did. Does anyone know if the collar can be removed without major surgery?
