What is the normal operating TEMP for a Stock 350??? Is 205degrees to hot???
Discussion in 'Troubleshooting & Diagnosis' started by 75ltexan, Sep 21, 2009.
  1. 75ltexan
    75ltexan Member
    56
    Jan 22, 2007
    I took my '75 stock 350 maro out for a Hwy. cruise. Most of the Highway trip was running around 185 degrees (2700rpms) , but when I went up to 3000rpms the TEMP went to 205degrees and stayed there. Is this a high reading??
    ps ---the car is due for a coolent flush.
    Thanks in advance, Mark
  2. onovakind67
    onovakind67 Veteran Member
    4,654
    Jul 8, 2001
    Fairfield, CA
    An engine running at 205° is not a hot engine at all.
  3. COPO
    16,048
    201
    Stock thermo was a 195* therefore on hot drives where you hammer the throttle it'll be +5* to +10* more.
  4. Gary S
    20,855
    236
    That is about right. If your cooling system can keep up 100%, you can expect to see that 5-10 degrees rise over whatever thermostat you are running. If the cooling system comes up short under certain conditions, the temp will rise more than that.
  5. ronald66
    ronald66 Veteran Member Lifetime Gold Member
    689
    Jul 11, 2008
    Italy,Rome,Nettuno
    mine runs at 180*,is that to low??im i risking something??
    thanks Ron
  6. doc221978
    doc221978 Veteran Member
    355
    Nov 29, 2008
    Allenhurst, GA.
    If your cooling system is very effective and you have a 160-180 t-stat, then running 180 would be fine. Depends on the engine and plugs, but typically 180-210 seems very normal. If I ever get to 220 I shut down, but that is just trying to be safe.
  7. COPO
    16,048
    201
    Below 180* is when you start to worry.
    The only reason the factory installed a 195* thermostat is so the car would pass emissions.
    If you go with a 160*, IMO, it'll be too cold. I like'm between 180*-190*.
  8. Lrader99
    Lrader99 Veteran Member Lifetime Gold Member
    894
    Sep 18, 2005
    NW Georgia
    engine oil temp needs to be atleast 160 water temp needs to be atleast 170 its not uncommon to see a water temp of 220 and an oil temp of 240. anything more than that its getting hot
  9. camaro19791000
    camaro19791000 Veteran Member
    103
    Feb 28, 2009
    El paso Texas
    I have a 160 thermostat, it runs 180 during the day wit out smashing the throttle, 200 when its smashed, and at night runs 160 smashed or not...is that fine?i always stopped the car when it got to 210
  10. BondoSpecial
    8,697
    Sep 20, 2004
    Southern Maryland
    Camaro1979, I personally would put a 180 in your car, and I bet it will still run the same temps 180-200 during the day, but at night the 180 stat will keep you from dipping below 180.
