What is the best size rims for no prep racing without tubbing
Discussion in 'Camaro Questions' started by Bigthirsty, Jan 2, 2017.
  1. Bigthirsty
    Bigthirsty New Member
    Nov 30, 2016
    Best size rims for no prep racing without tubbing
  2. 351maverick
    351maverick Veteran Member
    3,116
    159
    Aug 11, 2010
    erie, PA
    I'd rephrase that question if I were you
  3. Bigthirsty
    Nov 30, 2016
  4. DB Z28
    DB Z28 Veteran Member
    504
    15
    Nov 30, 2003
    Fond Du Lac
    10 in wide in rear
  5. Bigthirsty
    Nov 30, 2016
    Do I have to modify anything. I have a 10bolt rear rnd
    fast231 likes this.
  6. Camaro75LT
    Camaro75LT Masshole Staff Member Lifetime Gold Member
    6,590
    63
    May 17, 2001
    Boston-ish
    I'm sure you mean hypothetical street racing or no prep racing on a track. Nastyz28 does not condone illegal activities including street racing.
    Big tires out back has been covered hundreds of times on here. Search around. Keep in mind, when running slicks, c-clip eliminaters are a must.
  7. badazz81z28
    14,272
    122
    Las Vegas, NV
    What rim size are you looking to buy? A good size that will fit in most if not all second gens is a 275 tire with a 17x9 with 5" bs. That size won't require fender lip rolling or 5lb sledge hammer to the seat belt area
    Any bigger you might have to make clearance.
  8. 80sz
    80sz Veteran Member
    2,280
    183
    Feb 2, 2014
    Buffalo,n.y.
    275/50/15 bfg drag radials will fit stock rim are 26" tall and get you about 9" of tire on ground with zero mods .
  9. Bigthirsty
    Nov 30, 2016
    Your correct didn't mean street racing, but no prep. How do I change the question
  10. Bigthirsty
    Nov 30, 2016
    OK thanks
