What I did while it was -45 F in Alaska. #2
Discussion in 'Project Progress' started by frozenbowtie, Mar 3, 2008.
  1. frozenbowtie
    frozenbowtie Veteran Member
    119
    Jan 21, 2008
    Fairbanks Alaska
    There is a "PART 1" that has Nitrous and roll cage install
    FUEL SYSTEM:
    [[​IMG]
    Still need to plumb all the pressure lines for the fuel to flow...but ITS CLOSE!
    Man I am TIRED!!!;)
  2. John Wright
    14,391
    123
    Aug 9, 2002
    Rustburg, Va
    Hey...did you know that you got a big hole in the trunk?
  3. frozenbowtie
    119
    Jan 21, 2008
    Fairbanks Alaska
    Yeah I know.....but I plugged it!
  4. John Wright
    14,391
    123
    Aug 9, 2002
    Rustburg, Va
    Ah,..that's good because at -45F it might get a bit chilly with that huge hole in the trunk.
  5. woody80z28
    5,527
    40
    Sep 8, 2004
    walton, ny usa
    -45 is pretty cold for a t-shirt. Did you cut the hole in the trunk with your nipples? haha
    I'm looking at a fuel system myself right now. Good work.
  6. frozenbowtie
    119
    Jan 21, 2008
    Fairbanks Alaska
    [​IMG][​IMG][​IMG]
  7. jester1
    jester1 Veteran Member
    2,367
    Jan 12, 2005
    HI
    Im suprised no one mention the height of the fuel pump. Those pumps like to be gravity fed. JFYI.
  8. frozenbowtie
    119
    Jan 21, 2008
    Fairbanks Alaska
    Thanks for the info.....in that pis every thing was just dry fit......pump has been moved to under car location.....the spot where you see it was where it has been for a coupl years tho......once again thanks!!
  9. tom3
    tom3 Veteran Member
    11,258
    175
    Aug 1, 1999
    ohio
    Bet that torching stunk up the place in that closed garage. Nice looking install though. Come on summer!
  10. 70rs00z28
    70rs00z28 Veteran Member
    547
    8
    Apr 16, 2002
    Yankton, SD
    Your more dedicated than I am I haven't touched my camaro all winter. It is too dang cold in the garage right now. I am hoping to finish my floorpans this spring and then I will be doing the fuel system as well.
