What Chevy perf. crate engines fit under 1981 Z-28 air induct.hood
Discussion in '1978 - 1981 Specific' started by Jim Dreu, Aug 20, 2017.
  1. Jim Dreu
    Jim Dreu New Member
    Aug 20, 2017
    Iowa
    Hi looking for some help to see if any one has installed a Chevy crate engine under a stock 1981 Z-28 air induct hood. Was looking at Chevy performance SP350/357, SP350/385 orZZ6 engine. I'm trying to keep everything under a stock hood. Or other crate engines that do work. :)
    Thanks for the help!!
  2. Zspoiler
    Zspoiler Veteran Member
    2,195
    116
    May 6, 2012
    Federal Way, Washington
    Most any carburated small block will fit Use a Performer or equivalent manifold will fit.What "look" are you looking for.
  3. ULTM8Z
    ULTM8Z Veteran Member
    8,491
    122
    May 19, 2000
    Los Angeles
    Yeah the intake manifold typically drives Underhood clearance along with the air filter assembly. Pretty much any dual plane manifold will fit with a typical air filter.
  4. badazz81z28
    14,522
    145
    Las Vegas, NV
    LS3.....lol
    A RPM Performer intake will require a drop base cleaner, but it will fit.
  5. dailycruiser81
    dailycruiser81 Veteran Member
    200
    10
    May 19, 2013
    ft lauderdale
    I had a real hard time with hood clearance on my 81. Went with the yearone crate motor and it cam with a performer rpm air gap. Ended up with drop base bottomand a 2 ans 1/2 k&n with a flat filter top to get it not to hot my hood. I think the fresh motor mounts brought it up some.
  6. Jim Dreu
    Jim Dreu New Member
    Aug 20, 2017
    Iowa
    Thanks! I was thinking the "sleeper" look, thus keeping the stock hood in place.
  7. Jim Dreu
    Jim Dreu New Member
    Aug 20, 2017
    Iowa
    Thanks!
  8. badazz81z28
    14,522
    145
    Las Vegas, NV
    I forgo....Also lose the wing nut. Cut the air cleaner stud down and just use a hex nut.
  9. Zspoiler
    2,195
    116
    May 6, 2012
    Then what ever small block you get just paint it factory blue,including the intake..And use an earlier Q-jet and distributor,Since yours is computer controlled.
  10. budro6968
    budro6968 Veteran Member
    1,963
    259
    Apr 2, 2016
    Jax Florida
    Even a big block will fit. Just have to worry about the air cleaner hitting. Can't use a high rise intake with spacer. You could go with a different hood like Z spoiler, but the sleeper look will be gone. Then you won't have to worry about clearance as much.
