What Carb to run on my full roller 355?
Discussion in 'Engine Topic' started by ddc456, Dec 6, 2011.
  1. ddc456
    ddc456 Veteran Member
    490
    Oct 11, 2010
    Oregon
    I have been told everything from a 650 to 750. Truely what should i run? It's going to have a tko 600 behind it.
    Thanks
    Doug
  2. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    The 650 DP is plenty.
  3. Notalent
    Notalent Veteran Member
    489
    Jan 27, 2010
    Dallas/LBC
    I concur. You cant beat it. If you need a street carb, the Quick Fuel HR-680 would be a nice deal as well, but for best performance the 650DP.
  4. frankz
    frankz Veteran Member
    2,075
    Aug 24, 2009
    Illinois
    You guys are pretty good.........I don't have a clue what heads,compression,intake or camshaft make a "full roller" .
  5. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    Full roller don't tell us much. No way we can tell you what carb size you need with out knowing ...
    What cam size, what heads, what compression,
  6. Notalent
    489
    Jan 27, 2010
    Dallas/LBC
    Considering its a 355CI most likely not high compression and under 500HP and most likely not going to RPM over 6000RPM...its not difficult to select a carb. Most people over carb as it is. There is a simple math to it and being around engines of all calibers helps.
  7. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    It is possible he has 18ยบ heads, locomotive springs, .750" lift etc etc where a 1050 would be his best choice. But most folks with that kind of motor already know which size carb to use.
  8. 5spd540
    12,353
    12
    Sep 19, 2009
    Guyton, GA
    I would say 650 to 750. If it was me I would go quick fuel 750
  9. ddc456
    490
    Oct 11, 2010
    Oregon
    Sorry guys left out some details. 2.02 heads, 10.5 pistons, cam 280h, lift 480 duration 230 @ 50 lift ......sorry guys when it comes to motors i know little. i bought this from my father who had it built a yr ago for another that has never been ran. Talked to a good friend of mine today and he was saying really no need for a 750 on a SBC.
  10. mjoc
    mjoc Veteran Member
    3,504
    Apr 29, 2003
    Sherman Oaks, Ca
