Water temp gauge...
Discussion in 'Electrical Systems' started by RattyRedZ, Aug 31, 2016.
  1. RattyRedZ
    RattyRedZ New Member
    28
    Aug 28, 2016
    Maine
    Having problems getting my temp gauge to read right, I grounded out the temp sensor wire and it will jump hard right(hot) so the gauge seems like its ok, but when I hook the wire back up to the sender it will jump up to 100 when you turn on the key but never gets any hotter. I replaced the sensor/sender and it's still the same. My sender is not in the cylinder head, it is in the thermostat housing. Help.
  2. RattyRedZ
    28
    Aug 28, 2016
    Maine
    Would a stuck open thermostat cause a reading that low?
  3. slayer021175666
    slayer021175666 Veteran Member
    1,213
    57
    Feb 29, 2016
    Idaho
    Mechanical gauges are the way to go, IMO. Can you swap it out? At least connect one temporarily to see what reading it gives.
  4. loyal guardian
    loyal guardian Veteran Member
    697
    Aug 28, 2013
    helena mt
    i cant help you with the wiring but i can say that our explorers temp gauge is broke in the cold position/open position. its better than the closed/off position because i can still drive it without stopping every mile to let it cool down i just have to watch where the needle is.
  5. typeomang
    typeomang Veteran Member
    179
    May 25, 2011
    okc, ok
    my sender was in the head. I had to go to quite a few parts stores until I got one that would read right. GM had many the same style senders and the ohm's are different........1SG (RET)
  6. RattyRedZ
    28
    Aug 28, 2016
    Maine
    Problem fixed, moved sender from thermostat housing to lower spot on the intake, now it works, wish I had done that before buying a new sender:mad:
  7. camarolife78
    camarolife78 Veteran Member
    545
    Jul 22, 2014
    Gardner, KS
    Do you still have your old temp sender? I ask because a lot of the aftermarket parts store senders tend to read hot. I would keep the old one around until you verify the new one stays working.
  8. drewclonezap
    drewclonezap New Member
    18
    Nov 17, 2017
    Don't see how that could make any difference, but congratulations
  9. harbone66
    3,500
    284
    Feb 15, 2011
    Central Illinois
    Maybe an air pocket in the tstat housing?
  10. COPO
    16,709
    350
    In the housing it will only read when the stat is fully open and be useless when driving and if it partially closes or fully closes. Never install it in the housing, always go for the drivers side head.
    PalmbchZ28 likes this.
