water spots on glass
Discussion in 'Detailing Topic' started by delete-Z, Apr 10, 2011.
  1. Red 69
    Red 69 Member
    My vote is for Bon Ami. It will take all the film, water spots, bugs and about anything else off and not scratch the glass. I sprinkle some on a damp sponge and have at it.
  2. MassD
    MassD Veteran Member
    211
    Feb 20, 2011
    NonOfYourBusiness
    Just get some rubbing compound and work it into the glass by hand. Comes out like glass lol
  3. hoov81
    hoov81 Veteran Member Lifetime Gold Member
    764
    10
    Oct 31, 2010
    kenosha, WI
    Wow steel wool on glass sounds risky
  4. theflash
    11,021
    20
    Feb 27, 2004
    Podunk, CT
    I found that rain-X will sometimes remove water spots
  5. 5spd540
    12,353
    12
    Sep 19, 2009
    Guyton, GA
    I use 3000 grit micro mesh
  6. Rand
    Rand Veteran Member
    171
    8
    Jun 15, 2007
    Illinois
  7. John Wright
    14,390
    123
    Aug 9, 2002
    Rustburg, Va
    We used the extra fine steel wool to polish the glass exposure tubes in our blue print machines here at work....no scratches or the blue prints would have unwanted lines on them.
  8. Kamikaze
    Get a high speed buffer with a wool compounding pad and use a heavy duty rubbing coupound, (I use 3M) to cut fresh paint. It will break down and polish the glass as you go and blend in other spots as well.
    Been doing this over 30 years and it also helps on front windshields to clear up scratches from bad wiper blades.
  9. kawboy
    kawboy Veteran Member
    542
    Apr 2, 2010
    Indiana
    If you use steel wool just make sure that you blow the car off very well with a blow gun before getting it wet. You don't want little rust specks.
