Water leaking above heater box onto floor
Discussion in 'Troubleshooting & Diagnosis' started by Caelan, Aug 22, 2017.
  1. Caelan
    Caelan New Member
    Aug 22, 2017
    I have water leaking in from somewhere under the hood. I can see it running above the heater box with the dash out inside and then onto the floor. Anybody else have this problem or have any idea as to where it could be coming from?
  2. BonzoHansen
    one place to look is the seam sealer along the cowl. or a leaking windshield.
  3. Caelan
    Caelan New Member
    Aug 22, 2017
    It seems like it's coming in through the cowl in the hood dropping down into the firewall and continuing from there
  4. jamieg285
    jamieg285 Veteran Member
    1,257
    Jul 15, 2004
    Luton, England
    I had leaks where the lower/inner cowl panel joins to the kick panel.
  5. Caelan
    Caelan New Member
    Aug 22, 2017
    I'm thinking it may be the body sealer on one of the joints
  6. Alan Burg
    Alan Burg New Member
    12
    Aug 16, 2017
    I was just reading about this elsewhere. If the heater box under dash and if you have a/c the evaporator box are not properly sealed with rtv or some other sealant you can get water leaking through the heater box onto your floor
  7. gas and guns
    gas and guns New Member
    12
    Aug 24, 2015
    mi.
    Do not overlook the inner cowl itself. My 71 was rusted through on the left side of steering column. This caused my drivers side floor board to rust out. I didn't see it till I removed my dash and steering column.
