Warning for Vintage Air users
Discussion in 'High Tech Retrofits' started by Goat, Feb 21, 2018.
  1. Goat
    Jun 7, 2001
    moncure, NC
    This may be common knowledge for some, but I don't remember anyone mentioning this before.
    Anyway, when I was running the hoses (water and Freon) through the inner fender well (as directed), I found that the screws around the outside perimeter securing the fender to the inner fender well were very sharp (see photo) and intruded into the passage way about 1/4". This creates an opportunity for hoses to be punctured over time.
    Routing these hoses was not fun and I don't want to be doing it anytime soon, so I ground down the screws and carefully de-burred the edges. There are at least three, maybe four screws that can reach the hoses.
    mrfleet12 and Mike-78 Z-28 like this.
  2. badazz81z28
    Las Vegas, NV
    I found that out the hard way too. My car is lowered so I’m using pan head fasteners. Anyway I dropped the inner fender slightly to get better access, once I put the fender back up the hose was stuck! That’s how I found out those screws protrude right up in there. I pinched a hose between the fender and the screw head
  3. Mwilson
    Mwilson Veteran Member
    did you get it done?
  4. xten
    xten Veteran Member
    Sep 24, 2014
    Pittsburgh, Pa.
    Something else to add to the "To Do" list. Those hoses were ignorant, and replacement was going through my head during install. Thanks Goat.
  5. Goat
    Jun 7, 2001
    moncure, NC
    Yep. Cake once you know what you're doing...
  6. 1971CamaroGuy
    1971CamaroGuy Veteran Member
    Oct 31, 2004
    That's one of my complaints about the Vintage air kit, they started selling these with the hidden hose option as standard. So I got the hidden hose kit as well...which makes routing more of a pain than the previous kits where the hoses came through the firewall in the stock evap case location.
  7. Scarebird
    Scarebird Member
    Apr 21, 2013
    Bothell, WA
    I was not too thrilled with the routing either. I made a pair of hose clamps to hold the hose to the inner edge of the outer fender. The compressor hose just ran back to the bulkhead. VA is a little too hot-roddy for me, I prefer the OEM look.
