Wanted : 1971 350 Engine or block
Discussion in 'Swap Meet Section' started by 7173LT, Dec 2, 2017.
  1. 7173LT
    7173LT Member
    50
    Mar 21, 2017
    Looking for a July cast date 010 block . Whatya have? Thanks in advance.....
  2. 74BIBELOT
    74BIBELOT Veteran Member
    49BC9202-D883-4528-A08D-1AD67D19DDD7.png 8BE6A18D-96DA-4101-8864-0AD7C3FB3C52.png Not sure if you can use this
    CGC engine code
    T0625CGC
    2 bbl.
  3. 7173LT
    7173LT Member
    50
    Mar 21, 2017
    That might work. You have the numbers on the rear of the block? 3970010? and the actual cast date also? Where are you located?
    Thanks a bunch
  4. 7173LT
    7173LT Member
    50
    Mar 21, 2017
  5. 74BIBELOT
    I live on El Paso Tx, but back and forth from Juarez, Mx.-EL Paso Tx.-Las Cruces NM from April to November ( racing season)
    Let me get to he block this weekend to check for casting and date numbers.
    Regards
  6. 7173LT
    7173LT Member
    50
    Mar 21, 2017
    Sounds great! Thanx
  7. 7173LT
    7173LT Member
    50
    Mar 21, 2017
    Great thanks
  8. 74BIBELOT
    D4741B4A-4B01-4246-951A-87A024400265.jpeg 65BAECCC-1498-426E-B715-EECDAE9250B6.jpeg 4DA9D676-F3A3-4BD9-8EE8-4970D3188594.jpeg Casting # 3970014
  9. 7173LT
    7173LT Member
    50
    Mar 21, 2017
    What I really need is the casting date on the opposite side of the rear of the motor if you could please.. starts with a letter..
  10. 74BIBELOT
    1C9169AB-A945-4A2A-93EA-5F812F0AEEB9.png Let me check again, lost my phone charge today to get more pics, checking another old engine found this, not sure if CTB or CTR-K.
    Ps. Snowing here!!!
    Regards
