Valve cover breathers and Catch cans
Discussion in 'Engine Topic' started by Seventy1ProTour, Dec 2, 2017.
  1. Z28zz383
    Z28zz383 Veteran Member
    790
    May 11, 2012
    Florida
    That is pretty slick. Lot of ingenuity went into thinking it up. And making it work right.
  2. 8pack
    2,262
    58
    Aug 29, 2007
    Pittsburgh, PA
    I am running 2 hollow PCV and COPOs catch can. Solved a bunch of issues and oil leaks.
  3. muscl car
    Been running a Pan Evac set up for 15 years on my 350sbc with no issues . except for changing breathers and reed valves on a periodic basis its worked awesome
    What i like is no more oil contamination intake the intake
  4. Seventy1ProTour
    Seventy1ProTour Member
    61
    12
    Oct 18, 2017
    Huntersville NC
    I feel more confused. Should I just leave the 2 breathers on the driver vc and just clean it up every now and then again?
    Or add a breather to the passenger vc?
  5. mrdragster1970
    My 2 cents, make everything as tight as possible, add 1 line to a small puke tank & you're done cheap.
    If you want to do it right, add something to actually remove the windage from the pan.
    Evac system, electric vac pump into a puke tank, or a belt drive pump.
    If I was running something that was actaully street able, I would run the elect vac pump off a diesel into a puke tank.
    No parasitic loss, and you gain a tiny tiny bit of HP without contaminating the charge.
    camaro71/holland likes this.
