Vacuum leak in fuel control mixture valve
Discussion in 'Troubleshooting & Diagnosis' started by frozencaveman, Nov 23, 2017.
  1. frozencaveman
    frozencaveman Member
    38
    May 24, 2010
    Davis, CA
    Anyone know if there's a way to repair fuel control mixture valves? I have a 1967 Camaro with AIR system and discovered a vacuum leak on the original valve that required me to remove it - at the moment I've got it blocked off.
    Saw one on Ebay for $175 untested as a core, which seems to imply that someone out there rebuilds these things. Any ideas?
    Thanks,
    John
  2. larrylarry
    larrylarry Veteran Member
    1,475
    58
    Dec 22, 2011
    San Antonio Tx
    If you dont have to use that thing take it completely off there junk!!
  3. larrylarry
    1,475
    58
    Dec 22, 2011
    San Antonio Tx
  4. frozencaveman
    38
    May 24, 2010
    Davis, CA
    Yeah, I understand I don't need it, but I'm trying to keep the car 100% stock - it's only original once, right? I read an article about deveining the smog pump when the mixture valve goes south, but I'm not sure how the mechanics of the mixture valve work as far as repairing it or the conditions under which I can leave it installed (and leaking).
