Using shims on a hood hinge?
Discussion in 'Body Restoration' started by RS1979, Feb 5, 2018.
  1. RS1979
    3,238
    472
    Jun 18, 2013
    Memphis, TN
    My hood has been out of alignment since I got the car. Yesterday I got it straightened up but I noticed that the gap was tighter on the passenger side than on the drivers side. Can you use shims on a hinge to even out the gaps? I aligned it so that the stripes were straight.
  2. COPO
    16,853
    371
    Every hinge has shims from the factory. The ans is yes.
  3. Green hornet
    Green hornet Veteran Member
    1,517
    231
    Oct 11, 2015
    North Bay, CA
    My hood gaps are just like yours. If I try to correct it the hood stripes would be off. I'm fine with it.
  4. Smokey15
    Smokey15 Veteran Member
    2,281
    935
    Aug 13, 2017
    Pics and I can probably tell you how w/o shims.
  5. RS1979
    3,238
    472
    Jun 18, 2013
    Memphis, TN
    I’ll take some tomorrow Smokey
  6. Lou6t4gto
    Lou6t4gto Veteran Member
    329
    15
    Aug 18, 2010
    Ocala, Fla
    hood hinges do Not have shims from the factory.
  7. ronzz572
    1,909
    50
    Feb 8, 2007
    imperial pa
    I've never seen 2nd gen hood ever with a shim. There shouldn't be any needed to adjust hood gaps.There is a lot of adjustment in the hood hinges. Post some pictures of what you have? Im sure there is a answer for your situation.
