ultra rare 70z-28
Discussion in '1970 - 1973 Specific' started by creeker70, Nov 25, 2017.
  1. 70lt1z28
    2,420
    355
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Good catch on that! Easy to see once you pointed it out.
    http://nastyz28.com/threads/1970-z28-fender-hole.313793/
  2. 70lt1z28
    2,420
    355
    Oct 3, 1999
    In the same picture, it kind of looks like the core support has been replaced also. It looks like the standard radiator-replacement opening width, not for the heavy duty/Z28 radiator.
    Compared to Charley's car: http://www.1970z28camaro.com/engine/0010.jpg
    It looks like the opening width is narrower. Perspective may do it, but compare to the top cover plate where the end bolts are and drop down. Charley's car is just about even with the top cover plate bolts where this car is well inboard.
  3. creeker70
    creeker70 Member
    82
    May 31, 2013
    b.c. canada
    as far as I know and I know the history of the car and the owners including myself.the fenders are orig. and the rad support cover is the orig. also the owner before me had other hood hinges, fender support bars,rad support cover chromed but kept the originals which are on the car now so I don't what you guys are seeing, sorry thx
  4. roeville
    roeville Veteran Member
    1,138
    52
    Oct 9, 2000
    SF East Bay CA
    Just to help illustrate what they are talking about:
  5. 70lt1z28
    2,420
    355
    Oct 3, 1999
    Yeah, the support COVER is original, I was pointing out the core support itself looks like a base motor/replacement. When you buy a replacement, the opening for the radiator is sized for a 20.5 inch radiator, not the heavy duty/ z28's larger 25 inch width. Many times the body shop will just install them as the radiator will just drop in but then ~3 inches on each side of the radiator core is blocked from airflow.
    See this: http://nastyz28.com/threads/1970-z28-and-ss350-radiator-supports.127782/#post-1288299
  6. creeker70
    creeker70 Member
    82
    May 31, 2013
    b.c. canada
    ok I see now wow you guys know your stuff thanks for the info
  7. 70 SS/L78
    2,539
    57
    May 5, 2005
    Rockford, MN
    Good catch Dale!
    Beside the narrower opening for the radiator, replacement core supports are also missing the large round hole for the air conditioner line, to the left (drivers side) of the radiator opening. Assembly line core supports had the hole with or w/out AC
    EDIT: I should say all cars with heavy duty cooling (large opening) with or w/out AC
  8. 70lt1z28
    2,420
    355
    Oct 3, 1999
    Not sure if you have access to the car anymore, but the next easy thing to check is the left fender and the easiest way to verify it is the washer bottle mount. Replacement fenders (GM or aftermarket) have an incomplete metal plate where the washer bottle mounts. It is cut on about a 45 degree bevel and you can only get one washer bottle screw in then (the spot for the other screw isn't even there then).
    With the fender changed and the core support, this seems to indicate some substantial front end damage somewhere in its history. Is the radiator tag correct?
    Rust is sometimes the cause, but with this low of miles that would be unusual.
  9. 70lt1z28
    2,420
    355
    Oct 3, 1999
    They all had the hole, Scott? Darn, I thought I may have had the one-of-none 1970 Z28 with AC. Better sell all the AC stuff then.
  10. CamarosRus
    CamarosRus Veteran Member
    The changed fender and changed core support causes immediate concern on many levels.
    This thread can go on for pages and pages...........but "BUYER BEWARE"
    You cant trust ANYTHING that is being stated about this car without EXPERT inspection
