Turn Signals Not Working
Discussion in 'Troubleshooting & Diagnosis' started by billscamaros, Apr 11, 2011.
  1. billscamaros
    billscamaros Member
    50
    Apr 6, 2008
    Charles Town, WV
    '69 Camaro .... turn signals stopped working for both left and right side ..... all other lights work. That would be a switch or relay mounted near the fuse panel?
    Thanks
  2. ls777z
    ls777z Veteran Member
    2,101
    Feb 19, 2000
    Clay,NY
    You should be looking for a 1" diameter round silver fuse. It should be, if I remember, on the edge of the fuse block. If not there it would be hanging down under the left hand side of the dash......it's been awhile....
  3. billscamaros
    billscamaros Member
    50
    Apr 6, 2008
    Charles Town, WV
    Thanks .... I'll check tonight. That sounds right, but as you said .... it's been awhile since I had to mess with turn signals!!
  4. Gary S
    21,437
    412
    I don't know how the 69 Camaro was put together, but on the 70 and later Camaro, there are two signal flasher units. The one on the fuse panel is for the 4 way hazard flashers. There is a second one mounted on a clip up under the dash near the steering column that does the turn signals. If the 69 is the same, this is the one you need to check out, not the one on the fuse panel.
  5. firebird69racer
    firebird69racer Veteran Member
    233
    Oct 14, 2006
    San Bernardino,Ca
    69 is the same.
    It is under the dash between the steering column and the radio.
    I just posted the same thing in the other turn signal thread :cool:
  6. firebird69racer
    233
    Oct 14, 2006
    San Bernardino,Ca
    Also check the turn signal fuse in the fuse block
    The second one up from the bottom on the right. 20 amp
  7. hoov81
    hoov81 Veteran Member Lifetime Gold Member
    764
    10
    Oct 31, 2010
    kenosha, WI
    Hopefully your fuse block doesn't look like this
  8. firebird69racer
    233
    Oct 14, 2006
    San Bernardino,Ca
    No. It is a spare one I have laying around. :eek: I know it is kinda of rusty :D
  9. LtRsZ
    LtRsZ Veteran Member
    904
    Apr 12, 2010
    Tacoma, WA
    swap the hazard and turn lamp flashers and see if the problem also swaps
  10. david.carlton@s
    david.carlton@s Veteran Member
    1,075
    Sep 1, 2009
    CA
    I chased a intermittent turn signal problem for six months. Replaced flashers, wiring, etc. It turned out to be the fuse. The fuse contacts were rusted just enough to keep it from making good contact. Pull them and clean the contacts.
