Turn signals 1973
Discussion in 'Troubleshooting & Diagnosis' started by RonnieD701, Dec 22, 2017.
  1. RonnieD701
    RonnieD701 New Member
    Dec 22, 2017
    Ok, so I'm new here and was hoping for some help. My 73 camaro that I recently purchased has no turn signals. I've replaced both flashers.. hazards work fine.. turn signals.. nothing. Should I have power on one side of the signal flasher when blinker switch is engaged? I cannot get any current at the flasher itself.. all fuses check out good and all the bulbs work fine when hazards are on.
  2. bourbon_scotch
    2,017
    52
    Jan 10, 2003
    USA
    You should. Does the car run? Is the ignition switch on?
  3. RonnieD701
    Dec 22, 2017
    Thanks for the reply.. I finally figured out that I had a bad connection in the fuse panel. All is working fine now. Just one of those things that drives you crazy! Then you find it and feel stupid for how simple it was!
