Turbocharged 70 RS project
Discussion in 'Project Progress' started by Turbo70Camaro, Jun 12, 2010.
  1. z28code
    z28code Member
    50
    May 4, 2008
    ont
    You changing your car chuck?
  2. muscl car
  3. muscl car
    yep those parts will definitely be used ASAP !!! :)
  4. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Wiring started finally
    Fuel pump and Trans fan relay module mounted and wired in except for the trigger wires, moving forward.....................................................:screwup:
  5. muscl car
    Looks good Jake !!! :)
    What model or mfg are those relay/fuse panels and if you can let me know your wire sizes , fuse sizes and relay size
    I'm wanting to do the same thing for my electric fuel pump , electric water pump and fans
  6. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Its a dual 70amp relay board from Leash Electronics and the wires coming from the pump and fan to the unit are 10ga +/-, 4ga + feeding the board, 14ga - coming out and finally not shown 14ga to the switches.
    30 amp fuse for fuel and 20amp for trans fan Littel Fuse mini's.
  7. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Some more stuff fabbed up and done.
    Switch panel assembled:
    And the Pro 4 Relay board for 4 of the switches
    More wiring every time I finish something geeeez.
  8. muscl car
  9. Turbo70Camaro
    2,136
    112
    Jan 7, 2005
    so cal
    Wiring schematic I came up with and approved by Randy @ Leash Electronics
    I hate wiring, not good at it at all. I'm getting a mental block as soon as I start to do/think of how I want to run everything, I have gotten compliments from actual professionals on the wiring I have done but still no confidence. The crazy thing is this is the easy part of it, I need to figure out Hot/constant/key, light switch for gauges and so on.. :screwup:
    Here's the start of the actual switch panel wiring
    71RSLS likes this.
  10. DENALI
    DENALI Veteran Member
    1,093
    19
    Nov 4, 1999
    Sonova Beach
    Do you have any details on how you mounted your trans cooler? Thanks!
