Trouble finding a starter
Discussion in 'Engine Topic' started by zylow1980, Dec 30, 2017.
  1. zylow1980
    zylow1980 New Member
    Jan 17, 2011
    El Paso, TX
    I'm having trouble with finding the correct starter. I have a 79 camaro with a 350 from the mids 80's attached to a tko600. I've had trouble actually getting a good id on the motor because the code on my motor doesn't seem to show up anywhere else (V0626UPJ/4088548 for the curious). I don't have an old starter to reference either. I've grabbed a couple from the parts store and tried with no luck.
    Is there a better way to go about this aside from grabbing starter after starter untill one works?
  2. dave@ztech
    903
    81
    Mar 27, 2016
    NY
    what did you do with the old one?(starter) I assume you have it, take it to the NAPA parts store near you and have them find a replacement
  3. McCune
    McCune Veteran Member
    818
    113
    Aug 22, 2015
    st.george utah
    What size clutch is in front of the tko600?
  4. zylow1980
    Jan 17, 2011
    El Paso, TX
    Yeah that would be the obvious choice. I do not have the old starter though. As for the clutch, I believe it's an 11in clutch. I put it on but the car went into storage and sat there for a number of years.
    Here's what I'm looking at.
  5. dave@ztech
    903
    81
    Mar 27, 2016
    NY
    looks like there is a knock out scribed on the plate, did you ever have a starter in this car? With this setup?
  6. McCune
    818
    113
    Aug 22, 2015
    st.george utah
    Get a Lester # 6449 starter. Use GM bolts 12338064 and you are good to go.
  7. zylow1980
    Jan 17, 2011
    El Paso, TX
    Nope, never had a starter in it.
  8. Todd80Z28
    11,026
    64
    Jun 11, 2002
    Northern VA
    Might be a good time to figure out the right size Vortec starter... gear reduction and half the weight, needs less battery to crank over also.
  9. 8pack
    2,353
    70
    Aug 29, 2007
    Pittsburgh, PA
    +1
    I am running a power master vortec starter with my tko600 and stainless works headers on my 10.1 383. Fits great and cranks strong.
  10. McCune
    818
    113
    Aug 22, 2015
    st.george utah
    FYI, the 6449 is the gear reduction factory vortec starter.
