Transverse muffler exhausts
Discussion in 'High Performance Modifications' started by CAMLT74, Jan 13, 2010.
  1. CAMLT74
    CAMLT74 Veteran Member
    102
    Sep 27, 2008
    Fredericia, Denmark
    Hi. I have decided that I want a transverse muffler exhaust for my 1974 LT, mainly for the better ground clearence. The Dynomax super turbo I have now, gives absolute NO ground clearance. I have found 5 systems, but I need help to choose which one to buy. Opinions needed.
    Thanks
    Magnaflow 15895 $633
    Thrush 89021 $246
    Pypes SGF70 $500
    Flowmaster 17104 $446
    Waldron $410
  2. Twisted_Metal
    26,310
    618
    I used the Thrush system...... Did a write-up here. ----> http://www.nastyz28.com/forum/showthread.php?t=111795
    I think it works/sound/fits well but the Pypes system (stainless and twice the price) should be a better performance system.
    I had a local shop cut the tail pipes at a 45* angle for the Thrush system so they would look right. No tips are needed.
  3. GoldenOne7710
    GoldenOne7710 Irrelevant Member Lifetime Gold Member
    4,539
    297
    Jun 23, 2004
    Athens, GA
    If you don't want to fork out that much money for a complete system.....you could always order the muffler ONLY and have a reputable exhaust shop fabricate the rest.
    I bought the 80 series FM muffler only and had an exhaust shop install it with 2.5" pipes from the headers back with tail pipes.....they charged me $125.
    I used the transverse muffler mainly for ground clearance issues as well. I'm thinking about maybe swapping over to the Dynomax Ultra Flo muffler.
  4. CAMLT74
    102
    Sep 27, 2008
    Fredericia, Denmark
    Golden One, you want to switch the flowmaster system out, why?
  5. 73RSZ/28
    73RSZ/28 Veteran Member
    233
    Aug 26, 2008
    St. Peters, MO
    I have used the Flowmaster system on a prvious 73. Sound is good. Resonance is a little high in the cabin. A friend has the same system in a 68 with a high comp 302. Sounds awesome at 8000 rpm.
  6. CAMLT74
    102
    Sep 27, 2008
    Fredericia, Denmark
    GoldenOne and 73RSZ/28, do You have a soundclip of the Flowmaster system?
  7. CAMLT74
    102
    Sep 27, 2008
    Fredericia, Denmark
    I can see at the pictures in your thread, that the front pipes in the Thrush system isn't mandrelbend. I wonder how much it is going to hurt performance for the engine in my sig., if it is at all...
  8. chevyseve71
    chevyseve71 BANNED
    232
    Jun 15, 2009
    MWC,OK
    no trying to argue but you should watch a flow master muffler get tested for cfm ratings. its about 10% better than a stock muffler.
  9. noobwrench
    noobwrench Veteran Member
    465
    Mar 11, 2009
    Lodi/Burson California
    I have that same muffler. I got the muffler and had custom pipes installed for $300 at a local muffler shop. I had replaced a flowmaster with this muffler, and im much happier with it, more mellow at idle and sounds wicked when you get on it.
  10. BondoSpecial
    8,694
    Sep 20, 2004
    Southern Maryland
    ^did the muffler shop use stainless? The price difference for stainless vs aluminized is a big factor. I always end up cheaping out and using aluminized and then hating how it holds up a few years later
