Transmission pairing with a mild modified supercharged SB
Discussion in 'High Performance Modifications' started by NM1989, Dec 4, 2017.
  1. SRGN
    SRGN Veteran Member
    444
    139
    Feb 20, 2009
    Central NJ
    I saw a pretty violent transmission explosion on the dyno when an N/A high STR converter was installed in a nitrous car. The torque multiplication was high enough to scatter some really expensive internals when the second stage came on. Call a real converter builder for a recommendation. Neal Chance, Pro Torque, PTC, come to mind. If its an off the shelf unit from a wholesaler, you can be sure it won't be optimal to your combo.
  2. Second Affair
    Second Affair New Member
    17
    Dec 16, 2009
    central connecticut
    I've got a 406 with a 177 making 650hp went 10.94 @ 3950lb with 373 gears. the trans was a stock 350 that had been rebuilt 5 years ago, with a 3000 stall street converter. I don't know what was upgraded maybe the sprag and I asked for a shift kit. Then I bought a supposed high hp model and broke the sprag support. My advice would be find a good trans guy in your area and have one built. I had a local guy fix mine and he upgraded the high hp one I bought and got a better price.
